woodworkers & spoonsmiths - stock question
Got an unfinished laminate stock for a 10/22 build. Plain blonde color.
Would like to add a hint of color before I put a topcoat on, but all of the stains I can find are various wood shades. Would like to go with a green, blue, purple, or some other color. What are my options? Can either do a stain and then top coat w/ clear laquer, or a color tinted laquer for the first layer or two and then clear laquer after that to keep the color from being too much. Thanks! |
If you have a bit of the original left-over wood stock: Experiment a bit using different products and compare results.
Also good as a hole filler. |
I use leather dye now and then. Comes in many colors and is water based so you can spray lacquer over it.
The leather dye option sounds interesting... |
The typical hardware stores only carry the basics for staining. Try and locate a wood finishing supplier like Mohawk. Wood & Leather Touch Up & Repair Products by Mohawk Finishing
They should have both water soluble powder dyes and alcohol based dyes. You could also try a Luther supplier like Stewart MacDonald. STEWMAC.COM - Finishing Supplies Cheers Duane |
Be aware that colors/tones may change after a few months.
-Some dyes sit on the surface of wood. -Some are completely absorbed after a week or two. Wait before top-coating. Use gloves when handling. If absolutely necessary, temporarily finish using the same type of oil used in the stain. |
One of these oil stains would probably work: Interior Stain Colors - Sherwin-Williams
I've used this particular type of dye with great success as color for toning lacquer on old radio cabinets and some furniture.
Behlen Solar-Lux Non Grain Raising Wood Dyes |
Thanks guys.
Think I'm going a different direction - gonna do a thick base of clear water based laquer, rattle can it w/ black water based laquer, and have a buddy take his air brush to it with his water based paints. |
| All times are GMT -8. The time now is 02:45 AM. |
