woodworkers & spoonsmiths - stock question
Got an unfinished laminate stock for a 10/22 build. Plain blonde color.
Would like to add a hint of color before I put a topcoat on, but all of the stains I can find are various wood shades. Would like to go with a green, blue, purple, or some other color. What are my options? Can either do a stain and then top coat w/ clear laquer, or a color tinted laquer for the first layer or two and then clear laquer after that to keep the color from being too much. Thanks!
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
You do not have permissi
If you have a bit of the original left-over wood stock: Experiment a bit using different products and compare results.
Also good as a hole filler. |
I use leather dye now and then. Comes in many colors and is water based so you can spray lacquer over it.
The leather dye option sounds interesting...
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
The typical hardware stores only carry the basics for staining. Try and locate a wood finishing supplier like Mohawk. Wood & Leather Touch Up & Repair Products by Mohawk Finishing
They should have both water soluble powder dyes and alcohol based dyes. You could also try a Luther supplier like Stewart MacDonald. STEWMAC.COM - Finishing Supplies Cheers Duane
79 SC Daily driver. 3.2ss, twin plug 15 Toyota Tundra. Fox 2.5 DSC Look 695 Ibis Mojo HD Pivot Vault. Cross/comuter/winter bike |
Be aware that colors/tones may change after a few months.
-Some dyes sit on the surface of wood. -Some are completely absorbed after a week or two. Wait before top-coating. Use gloves when handling. If absolutely necessary, temporarily finish using the same type of oil used in the stain. Last edited by john70t; 06-17-2014 at 12:57 PM.. |
One of these oil stains would probably work: Interior Stain Colors - Sherwin-Williams
Neil 87 944S http://guns.claasen.us/ |
Serial Lurker
I've used this particular type of dye with great success as color for toning lacquer on old radio cabinets and some furniture.
Behlen Solar-Lux Non Grain Raising Wood Dyes
Does anyone know where the love of god goes when the waves turn the minutes to hours? |
Thanks guys.
Think I'm going a different direction - gonna do a thick base of clear water based laquer, rattle can it w/ black water based laquer, and have a buddy take his air brush to it with his water based paints.
