rfuerst911sc's Avatar
flashlight batteries how to keep them clean ?
Yesterday I purchased two cheap LED flashlights that use three each AAA batteries. I would like to keep these in the cars but past experience says they will start leaking battery juice at some point in time, I'm assuming from the heat. Anyway any tips on how to keep the batteries clean/stop leaking ? I guess the easy answer is change them every six months but easy to forget. Do you put any dielectric grease on them ? What about battery type ? Standard vs. alkaline vs. ??? It will cost more for the replacement batteries than the flashlights cost so I guess I could just throw them away but I don't like doing that.
Old 06-17-2014, 10:43 AM
Student of the obvious
LeeH's Avatar
How often will they get used? I pull batteries from things I rarely use. Put the batteries in a baggy. Put them in the flashlight if you need to use it.
Lee
Old 06-17-2014, 11:16 AM
Friend of Warren
Get led flashlights that use lithium batteries. Even the ones from HF work well and lithium batteries are relatively cheap if you buy in bulk.
Kurt V
Old 06-17-2014, 11:50 AM
vash's Avatar
I opted for an inexpensive flashlight that uses the cr123 batteries. They last for years untouched.
Sent via Jedi mind trick.
poof! gone
Old 06-17-2014, 11:51 AM
You can buy lithium batteries, I think, in AAA size.
Also, Duracell makes a Duro Core battery that will last years without leaking.
Your best bet is to buy a rechargeable flashlight with a lithium battery for normal use. Your emergency flashlight should use alkaline batteries that are changed annually.
Old 06-17-2014, 11:56 AM
wdfifteen's Avatar
This is what I do for all of my occasional-use things that take batteries.
Old 06-17-2014, 11:59 AM
vash's Avatar
Nitrolon G2 flashlight. In my wife car for maybe three years. Will still send out a blazing beam of light. I sometimes get boxes of free batteries so I will run it down and replace. An alkaline battery will leak. Unless you can follow a strict replacement schedule. It will fail.
Lots of cheaper flashlights and headlamps are not yet rated to run lithiums. Just read and article about it this morning. Apparently they put out just a tad more voltage?
poof! gone
Old 06-17-2014, 12:50 PM
From my own seat-of-the-butt testing, lithium batteries put out a lot more power, and will do so for a longer period of time than alkaline batteries. But Lithium will drop off suddenly, giving almost no warning that they are about to die, similar to Ni-cads.
That's why my go-to lights are all rechargeable Li-ion but the emergency, if this thing don't work them I'm screwed flashlights that I keep in vehicle toolboxes, are all Alkaline and they are changed regularly no matter what. If you are doing anything involving high value, use fresh alkaline or brand new lithium batteries.
Old 06-17-2014, 01:36 PM
cr123 cells are specifically designed for long shelf life. The energy storage is much higher as well.
07 Exige S
Old 06-17-2014, 02:28 PM
My G2s seem to like to self discharge in my glove boxes of my cars. I met a guy who make custom flashlights in WA. He modifies the drop ins and the electronics from an existing company to make them reliable. I have a couple make by him for very specific beam spreads. Worth the money IMO. I paid about $100
Old 06-17-2014, 05:23 PM
Fenix flashlights are fantastic value
07 Exige S
Old 06-17-2014, 07:04 PM
vash's Avatar
You turn the back cap out to prevent contact?
poof! gone
Old 06-17-2014, 08:23 PM
LeeH's Avatar
And then there's this:
Magnetic Force Flashlight | Electricity & Magnetism science experiments, teaching & education tools: Educational Innovations
Lee
Old 06-17-2014, 08:47 PM
A jack o light. .
Old 06-17-2014, 09:33 PM
Now I do.
Old 06-17-2014, 10:11 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
Use a handle turned charger flashlight, that way you dont have to remember about batteries.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 06-18-2014, 06:33 AM
