MBruns for President
OK Pelican Braintrust - Boat Engine - Inboard Mercruiser
So I have this boat - a Bertram 28 - It was my stepfather's boat -
Twin 1986 Inboards - 260HP 5.7 Mercruisers (1600 hours) The Port Engine started making this noise - and I can not figure out what it is. Changed the oil - and filter - no metallic pieces in the oil. (I have not cut open the oil filter - I guess I can do that next) Changed the water pump - it's new. Changed the fresh water pump - - It almost sounds like it's coming from the crank pully/harmonic balancer Other than the noise - the engine runs well - good oil pressure - runs at temperature. The Manifolds and Risers have been recently changed - https://www.youtube.com/watch?v=ufS3BQ5w14Q Any ideas?
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Gary H 1978 911 SC
It sure sounds outside of the engine block. Like a pulley or water pump or a accessory.
Gary H 1978 911 SC |
Parrothead member
Check the Harmonic balancer . I've seen the rubber inserts go bad on those, a number of times.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
The Unsettler
Exhaust or vacuum leak.
Sounds different because motor is in an enclosed space.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Air Medal or two
Unhook all accessories and fire her up (all belts all drives).
-(not for long, just enough to determine) If no luck - pull valve covers and check for" loose ones" . It sounds too tinny for a rod, but about right for a collapsed lifter .
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Thanks I'll have to try that
I second what Vin says. When the rubber lets go, the outer ring can move around. I have seen one saw through a timing cover.
No left turn un stoned |
least common denominator
I can't help you with the Mercruiser but dayam that sounds like one fine boat!
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
Still Doin Time
From the info and video my opinion: Def something directly tied to crank rotation related and def something outside the block. Like the balancer coming apart or flywheel / flexplate bolts as they connect to the trans. Quickest way as said above to remove drive belts and start engine to see if it goes away or changes. Then go from there to the rear.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Here's a picture of the boat ![]()
Grip It & Rip It
i like the boat and the dog too!
![]() Good Luck...hope it's the harmonic balancer!
82 911SC (sold) |
Yep - Harmonic Balancer - thanks for the advice - not too much drama getting it off - you can see where it was wearing on the timing chain cover (and obviously making noise)
![]() ![]() ![]() Thanks again for everybody's input!
Thread Tools | |
Rate This Thread | |
