1980 911 SC
Lightning strike- Can my new flat screen be fixed.
During a lightning storm the house got hit and sparks flew out of an electrical outlet that my new 40” Sony was plugged into. The outlet still works fine, no other visible damage to the house but the TV is not working. It will not turn on anymore. Does anyone think that if I pull it apart I might find an easy repair. I’m not a tech geek and it would have to be something readily visible that looks burned up and can be replaced easily. So, can this be fixed, would you even bother with it, or should I try it out as a surfboard.
Life's a Beach
Old 07-17-2014, 06:57 AM
Eva
911SauCy's Avatar
It's dead.
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 07-17-2014, 07:03 AM
"O"man(are we in trouble)
widgeon13's Avatar
Homeowners might cover depending on deductible.
Old 07-17-2014, 07:04 AM
Laneco's Avatar
It's already broken. So no harm/foul to take it apart and see if you can fix it. If you cannot, send it to the e-recycle.
Maybe you will get lucky and it is just the power supply portion that has failed. More likely there are several things damaged and the cost to repair it will exceed the cost to replace it.
angela
Hello
Old 07-17-2014, 07:05 AM
The Unsettler
stomachmonkey's Avatar
Depending on how new it is the availability of system pull parts will vary.
New parts will almost surely be too expensive to make fixing it worthwhile.
Do a search for the manual / schematic.
If it's got a protection fuse you may get off easy.
If not I doubt I'd bother.
"I want my two dollars"
"Brandon Won"
Old 07-17-2014, 07:42 AM
angela
What she said.
If you DO decide to open it up and see what you can do, look for the obvious: burned solder joints, popped capacitors, etc. When items such as this take an electrical spike like that, it can be as simple as a single circuit getting blown, or as bad as a whole lot of internals getting fried. If you're not wanting to upgrade (go bigger), 40" TVs are really pretty cheap these days...like, cheaper than your homeowner's insurance deductible, probably.
Guy
'87 944 (first porsche/project car)
Old 07-17-2014, 07:44 AM
least common denominator
scottmandue's Avatar
Just scored a 50" Samsung plasma from Costco for $700 out the door.
As has been said, most likely cost more to fix than it is worth... and I am a tech.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 07-17-2014, 07:51 AM
Z-man's Avatar
For prevention of this happening again, may I suggest:
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 07-17-2014, 08:19 AM
RF5BPilot's Avatar
Going forward, one thing to consider is a whole-house surge protector. They usually cost about $75-$200 and are attached to the main electrical panel.
James
Old 07-17-2014, 08:31 AM
Band.
Many times there is a fuse on the board thats only accessible when you take the back panel off. Maybe you'll get lucky!!
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 07-17-2014, 08:40 AM
A power conditioner would be even better.
Guy
Old 07-17-2014, 08:59 AM
Hi
Targa Me's Avatar
Here's my .02:
If sparks were flying from the outlet, I doubt a surge protector would have helped, but they're good to have for anything besides a direct hit.
I don't think Homeowners insurance would pay for that because, its an act of God, but you can check anyways.
If your house was a direct hit from lightening, I think that TV is completely fried.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 07-17-2014, 09:11 AM
Geary's Avatar
When our house was hit by lightning (in Hawaii no less), homeowners covered replacement of virtually the entire house wiring, and all the blown components. I got rid of all CFLs immediately.
Old 07-17-2014, 10:11 AM
Originally Posted by 911SauCy View Post
It's worse than that... it's dead Jim.
My edit
Gary Fisher 29er
1995 Miata Sold
1984 944 Sold
Old 07-17-2014, 10:18 AM
The Unsettler
Depends on the policy.
Lightning strikes are very common around here. I've had several friends, houses no more than a few doors away, who got hit and anything that got fried got replaced by insurance.
Electronics are the least of the worries. Every year in our community a house will catch fire or burn down completely during "the season".
"Brandon Won"
Old 07-17-2014, 10:19 AM
Sugar Scoops Rule :)
dave 911's Avatar
we had a Sony 40" that got fried by lightning a few years back, it was still covered by the Costco warranty (the Sony warranty had expired, gotta love Costco/AMEX warranty extension). They sent a tech out, he declared it dead, and we got a check that covered a new Samsung 46".
My guess would be dead....
Dave
_______________________________________________
'76 911S Targa
'62 VW Type 1 Sunroof
'73 914 2.0 (1st Porsche, gone long ago but not forgotton)
Old 07-17-2014, 11:11 AM
Gary H 1978 911 SC
Was it plugged into a surge protector? We were struck by lighting and the power strip had a 25K $ policy for lighting protection. 2 TVs, Amp, VCR, Telephones and some other stuff was all covered and we got a check for $2300. It was fast and easy.
Gary H 1978 911 SC
Old 07-17-2014, 11:30 AM
Formerly bb80sc
Vipergrün's Avatar
Open it up and take a look. You should be able to tell of something is blown. I got a new main board for an FG 46" for 100 bucks, good as new. As already mentioned, could be a simple fuse...
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 07-17-2014, 12:25 PM
1980 911 SC
There doesn't seem to be any other damage to house wiring or appliances, and the deductible turns out to be higher than the price of the TV. Looks like I'll do a little exploration given some of the info I've gotten here and hope there's a fuse or something easy to fix.
Thanks for all the advice, I appreciate it.
Life's a Beach
Old 07-17-2014, 01:31 PM
Student of the obvious
LeeH's Avatar
How new is new? Did you buy with your Amex? Visa? Many credit cards have damage coverage included as a benefit.
Amex bought my wife a new iPad when hers fell off the treadmill while she was running.
Also... some TVs do have replaceable fuses inside.
Lee
Old 07-17-2014, 02:20 PM
