UnRegistered User
Daiken also acquired the McQuay brand of heavier HVAC equipment and water chillers.
If you are going the route of replacing all the equipment in the next year or two, make sure that the components are matched well and that the line sizing is adequate for the new refrigerant that you will be running. Saving a buck at install time will cost you over the life of the unit. Keep the suction line as short as possible and well insulated. As was already mentioned check you supply system for leakage. A few days scrambling around your ductwork with a few rolls of foil tape (not duct tape) will do wonders for sealing up the system. If the ductwork is in a high heat area (ceiling space) make sure that it is well insulated after sealing. Handle the start capacitor with some care. It may offer you a little jolt if you don't! You can discharge them by shunting the terminals.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. Last edited by billybek; 07-25-2014 at 06:56 AM.. |
Just got an HVAC buddy on the phone who never answers his phone. Whew. He said, if it's running fine after replacing the fuse, then chances are very slim any of the capacitors are bad and it's most likely I just had an old fuse than was ready to go. This is comforting, but I'll be keeping a close eye on it from now on.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Banned
paid a buddy to do the el to code and went to a A/C parts place and hired a kid with a A/c repair van in parking lot to do line solder and the vac & gas fill after work for $100 cash did the unit install and ducts myself that was in a non-A/C house so everything from the slab to drip line inc for the 1k total |
B58/732
ΜΟΛΩΝ ΛΑΒΕ I don't always talk to vegetarians--but when I do, it's with a mouthful of bacon. |
Did/do you trust the installation contractor/dealer?
Maybe you got a lemon? Bad deal if a big problem. . Who ever is doing your repair, did they trash the Trane? ...bad-mouth the brand?
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View |
Gorilla
B58/732
No bad-mouthing of Trane from the guy who fixed it. He's definitely on my X-mas card list; stayed up on our hot roof for 3 hours fixing the screw-ups by knuckleheads #1 and #2.
Had the same issue here.
Guys showed up w/business cards with Contractor's lic. #'s...I checked w/the state and no such # or name.
Why does this stuff cost so much?
2.5t consdensor is ~1k. Shouldnt be more than a few hours to install. https://www.acwholesalers.com/Goodman-Air-Conditioner/GSX160301-2-5-Ton-16-SEER-Air-Conditioner-Condenser-R410A/32685.ac?catId=cat1000&mainCat=&subCat= |
Here are the units you see in AZ...big bucks.
. Trane-American Standard Gas Rooftop Air Conditioner Casa Grande, AZ
Good info, thanks.
Looks like they are at least twice what we use around here. For example, https://www.acwholesalers.com/Goodman-Air-Conditioner/GPG153709041-3-Ton-15-SEER-90-000-BTU-Gas-Electric-Package-Unit/14836.ac?question=ROOF |
Rick 88 Cab |
Yup. BTW, a/c is blowing ice cold now.
Student of the obvious
Rick - this company put in our AC in 2011.
https://plus.google.com/113187055363579032108/about?gl=us&hl=en Paid $5200 otd for a 13 seer Carrier. The guy really seemed to care about what he was doing. Our AC died in the middle of summer and he understood that the new unit had to be installed asap. His assistant wasn't available so he told me he had no choice but to wait a day. I told him I could help and he jumped right in. Our air handler was also in the attic of our single story house. We ended up cutting through the drywall and studs to get it out then just put it all back together when we were done. I took care of the drywall repair the next day.
Lee |
Thanks. I'll give them a call when it's time, but they're pretty far from me.
My Trane heat pump is celebrating 25 years this November. Zero---problems.
I know, I probably just f'd myself.
madmmac AKA Mitch 1984 Factory Turbo Look 2006 4Runner 1998 TRD Supercharged 4Runner (Sleeper) |
B58/732
I wish you many years of continued coolness!
Our 2 heat pumps were installed in 1988. No longer use the heating aspect and generally must cycle the breakers 2-3 times the first time cooling is needed in the summer. Most A/C compatible thermostats have a "restart" delay so the compressor is not commanded to start while head pressure is still elevated.
If some reason the compressor motor tries to restart with high head pressure a CB trip or blown fuse is a given. You need to be very carefull regarding adding a HARD START capacitor, you need to be certain/sure that the compressor motor is a capacitor START type, NOT a capacitor RUN type. Oh, capacitors are NOT used to store energy between starts, they are used to provide a START phase shift for a second motor winding when operating on a single phase supply system 120-240 VAC. That second winding is only powered during the motor start period, a few hundred milliseconds.. Last edited by wwest; 07-27-2014 at 08:35 AM.. |
Just gave away a still working freezer we purchased in 1978.
Thread Tools | |
Rate This Thread | |
