Sap removal from car?
The car has sat for two years. I power washed it with a strong detergent and there is still sap stuck to the paint. Tried 901 prep solvent and it didn't work. Went on line and several sites said mineral spirits. That didn't work. Tried a plastic pot scrubber with the same results.
What to use? rubbing compound? Or sand and repaint the whole car?
Bunch of old cars
Goof Off always works.
A clay bar will work as well.
I love you guys outside this forum ![]() -Eric |
Concentrated orange citrus cleaner. Let it sit just long enough to do the job. Wax afterward.
1989 911 Carrera Cab 25th Anniversary Edition Euro Pre-Muffler, SW Chip There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad" |
You do not have permissi
Gently clean area using water.
WD-40 on paper towel. Immediately follow with lots of water. |
It'll be legen-waitforit
Peanut butter...
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
Rubbing alcohol.
Driver, not Mechanic
Thanks for the tips. I have the same problem and tried claying it with little success. Will report back once I tried a few of these.
I have tried clay with little success. Now, how about the sap that's hardened? Any tips on that or try the same thing, WD 40 or other tip mentioned above?
Liberal use of a heat gun and a razor blade. Don't cut into the paint, just the glob of sap. Once you successfully cut into the sap glob and scrape much of it away, use the citrus cleaner to rub out the remaining sap.
Isopropyl (rubbing) alcohol should do it. Just use a microfiber cloth, or rub in with your fingers. One trick is to use a hand sanitizer gel so it clings to the sap long enough to dissolve it. You can also "fortify" it with (more) isopropyl alcohol if needed. You probably don't want to let it sit on the paint for too long though, and rinse with water immediately after. Then follow up with polish and/or wax.
Did you get the memo?
Lots of good suggestions here. Letting it sit on the sap to break it down is key. You can use a plastic scraper or old credit card to scrape the bulk of it off after your remover gets it soft, that's a less risky approach than a razor blade.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
WD 40 is pretty effective on my tree stuff.
it's like a clear booger coming from my local trees.
poof! gone |
Goo-Gone.
Also, if it's too thick that the Goo-Gone isn't penetrating well enough; heat it up with a blow dryer, scrape at it with something fairly rigid (paint scraper, credit card, etc) to get the "big chunks" off, then finish with the Goo-Gone.
Guy '87 944 (first porsche/project car) |
Before:
![]() After 30 seconds of WD-40: Should I let it sit longer? I only had a few minutes this morning. Will try Goo Gone and 99% alcohol later.
Goo-Gone really works. I recently debadged my Z; the badges were held on by adhesive. My car's an '03, so that's 11 years worth of adhesive--it was really on there. After getting the big parts off with hair dryer/credit card, the goo-gone took the residue off with ease.
The Unsettler
I just pull over and tell the sap to GTFO.
Easier not to give them rides in the first place.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
I've had the best luck with starting fluid. Quick burst, let it sit for a few seconds, and the sap just about wipes away.
Wild thing. That is crazy sap. Wd40 is pretty gentle. Maybe time to step it up? I like the starting fluid idea. Which is what use for road tar. Cheaper than tar remover.
poof! gone |
Isn't finger nail polish based on Acetone? I think Acetone is too aggressive for car paint. I would try mineral spirits, turpentine, or gasoline. Car paints are designed to be resistant to gasoline, turpentine is a distilled liquid tree sap product and should work on hard tree sap. Everything, of course, should be tried on an innocuous surface first.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
