"O"man(are we in trouble)
widgeon13's Avatar
What's this weigh?
Cherry 13.5 ft length and 20 in diameter.
Best guess or calculation??
Old 08-08-2014, 12:54 PM
Gary H 1978 911 SC
2800 lbs
Gary H 1978 911 SC
Old 08-08-2014, 12:59 PM
Almost Banned Once
sc_rufctr's Avatar
It looks like dense red wood so I'm guessing around 2 metric tons which is about 4,410 pounds.
- Peter
Old 08-08-2014, 01:09 PM
Hell Belcho
Nostril Cheese's Avatar
Just carry it. Its not that heavy..
Old 08-08-2014, 01:12 PM
Detached Member
Hugh R's Avatar
45 lbs/cubic foot wet, 35 dry. Using Pi and all that good stuff you learned in the 9th grade.
Hugh
Old 08-08-2014, 01:20 PM
pete3799's Avatar
1456lbs at 20"X13'
1568lbs at 20"X14'
http://www.woodweb.com/cgi-bin/calculators/calc.pl
Pete
79 911SC RoW
More than it would after I put one of my Stiihs into it . Without knowing if it's still green or not...no way to "guess" imo. I've tackled quite a few red oaks of that size over the past year or so...amazing the difference in the weight of similar sized logs from different trees. The 1/4 log that fell on my big toe last summer (and broke it) felt like eleventy hunderd pounds though
ps: Even if both are "dry/wet"...different trees (of the same species) seem to vary greatly from my experience.
Old 08-08-2014, 01:22 PM
wdfifteen's Avatar
Depends on the wood species and moisture content.
It's about 30 cubic feet, you can look up the density here.
Wood Species - Weight at various Moisture Contents
Old 08-08-2014, 01:28 PM
More than a henway.
Old 08-08-2014, 01:35 PM
That's a cool link Patrick. How come all the trees I seem to mess with are the heavies on that list . Oaks (red/white), Hickory, and Sycamore...I "passed" on the bigger portions of the Sycamore fwiw...
I still believe the species vary greatly even if wet/dry. I've had some 4' diameter trees (red oak) that were close to 200 years old, some much younger. The density/growth rings seem to vary from my experience.
ps: I know "counting rings" is a rule of thumb...I always thought it was 1 ring per year...a "tree pro" recently told me that's not always the case...live and learn.
Old 08-08-2014, 01:42 PM
Navin Johnson
TimT's Avatar
Are you going to use it for firewood?
You might be able to get a few hundred bucks for that if you sell it to a mill that cuts wood for cabinetmakers.. We got money for some ash that was on land that we cleared in Vermont....
Also if someone offer you Sycamore for firewood.... run don't walk away...its a ***** to split, and doesn't burn very well....
A few years ago I was offered free firewood, just had to take it away from my friends.. house...Two truckloads of unsplit Sycamore...
In hindsight my friends thinly veiled plan was to get me to help him clean his yard with an offer of free wood....I still have some of that wood ...hoping it will hurry up and rot
'69 911 GT-5
'75 914 GT-3
and others
Old 08-08-2014, 02:02 PM
widgeon13's Avatar
What's this weigh?
Hoping it will be a mantel
in our son and DIL's new home. It is cherry damaged in a storm two years ago. Have to get it around the house to a trailer and off to the mill. Thanks for the info.
Old 08-08-2014, 02:29 PM
Originally Posted by TimT View Post
...Also if someone offer you Sycamore for firewood.... run don't walk away...its a ***** to split, and doesn't burn very well....
Yep...I knew that beforehand, but was just doing a friend a favor too so I hauled the "little" logs away that were laying in his yard (1 truckload)...the 4'+ diameter ones are still there
Old 08-08-2014, 02:30 PM
My fellow nerds beat me to the punch
50lbs/cuft * PI*100 sqinch *(1/12^2) FT^2/in^2 * 13.5 FT
I get 'bout 1500 lbs
18 Cayman GTS
Old 08-08-2014, 02:46 PM
1966 - 912 - SOLD
lane912's Avatar
how many rifle stocks can you make from it?
i was too tired to be pretty last night!
Old 08-08-2014, 03:54 PM
FUSHIGI
grip it by the husk!
Old 08-08-2014, 03:58 PM
wdfifteen's Avatar
Ha ha! I had a similar experience. A HUGE elm came down on my property in the early 70s during the energy crisis. I thought I would heat my home with wood for a couple of years. I borrowed a 16 hp splitter and eventually managed to get it all shredded - er, "split." Ended up with about 4 cords. It burned like a wet sponge. I had to buy hickory, maple, and oak to get a fire going that was hot enough to ignite the elm.
Old 08-08-2014, 06:32 PM
vash's Avatar
it's official.
collectively, we are a genius!!
poof! gone
Old 08-08-2014, 06:39 PM
Navin Johnson
TimT's Avatar
You could probably get the mantle milled for free, and make some bucks.... That looks like a real nice piece... no branches, straight grain....or they mill for you... and keep the rest $
'69 911 GT-5
'75 914 GT-3
and others
Old 08-08-2014, 06:51 PM
pete3799's Avatar
You've got roughly 208 board feet in that log.
As a saw log it's worth about 187.00
If it's a veneer grade log it's worth about 624.00
Pete
79 911SC RoW
Old 08-08-2014, 07:22 PM
