-   -   Homemade radial VW engine , beyond cool!! (http://forums.pelicanparts.com/off-topic-discussions/826075-homemade-radial-vw-engine-beyond-cool.html)
fastfredracing 08-19-2014 11:57 AM
<iframe width="560" height="315" src="//www.youtube.com/embed/SyRJeZ6s8uM" frameborder="0" allowfullscreen></iframe>
billybek 08-19-2014 12:14 PM
Cool!
kach22i 08-19-2014 12:15 PM
I estimated once that there is about 25 HP per VW/356 cylinder, that would make it roughly 175 HP (25 X 7) for the 2.1 L displacement, right?
Does that check out with what they claim?
That propeller would not even clear a cowling cover, I'm guessing they will use something larger in diameter and this one was for static testing/display for start up.
Very cool, very cool.
The design, the engineering, the milling.............quite the accomplishment.
widebody911 08-19-2014 01:00 PM
Where did you get that number?
How do they lube the valve train?
wdfifteen 08-19-2014 01:08 PM
Very cool. It's amazing what skilled people with too much time on their hands can do.
I suspect the valve train is lubed through the pushrods like a VW.
I think 25 hp per cylinder is an over estimate. A 912 only makes a little over 100 hp, and this engine isn't tuned like a 912. Oops. 912 has 90 SAE hp.
widebody911 08-19-2014 01:15 PM
The rocker shaft assemblies are splash-oiled in a VW engine; the pushrods only supply a tiny amount of oil.
wdfifteen 08-19-2014 01:17 PM
Where does the "splash oil" come from? The pushrods. The rockers are drilled so the oil flows from the cup the pushrod rides in to the rocker shaft.
kach22i 08-19-2014 01:17 PM
I based it on the later and higher powered 356's which are just tweaked VW's anyway, sort of.
Right, 4 cylinders X 25 hp ea. = 100 HP total.
Same for a 911 engine more or less, 6 x 25 = 150 hp, similar to as early 2.7's
I did this simplified math for the reason of trying to figure out exhaust muffling, breaking it down per pipe.
Later 911's might be +30 HP per cylinder, early VW's only 10-20 hp.
That's quite a range, but like I said it was for gauging straight through muffler exhaust lengths.
EDIT:
Not the same engine, but interesting.
220 Hp Radial Engine Powered VW Beetle
http://americaloveshorsepower.com/radial-engine-powered-volkswagen-bug/
http://americaloveshorsepower.com/wp...red-vw-bug.jpg
Built by Continental, the W670-9A engine is rated at 220 horsepower. The engine was used in a variety of applications, and this 1941 model was pulled from an M2 tank. Bore is 5.125 inches with a 4.625-inch stroke, giving the engine total displacement of 668ci. - See more at: http://americaloveshorsepower.com/radial-engine-powered-volkswagen-bug/#sthash.buL80rjL.dpuf
Article on the engine which opened this thread:
http://www.enginelabs.com/news/homegrown-horsepower-radial-engine-constructed-from-vw-parts/
This estimate seems pretty low:
http://jalopnik.com/amazing-loon-built-a-radial-engine-from-vw-parts-1608661285
It seems to be a pretty compact power plant, and if I had to guess I'd say it may make between 80-100 HP? Maybe?
BlueSkyJaunte 08-19-2014 01:21 PM
That's freakin' amazing.
Builder: Arnold de Man.
De Man indeed!
Gogar 08-19-2014 01:27 PM
The end of the video states it's 2086cc, so it seems like each cylinder displaces quite a bit less than your average VW. Maybe the stroke is shorter?
really cool!
kach22i 08-19-2014 01:31 PM
Found this thread, many of the same questions being asked: not sure if it is the same engine
TheSamba.com :: View topic - Built: a VW 7 cylinder radial engine!
Beetle1950
Hello,
I made a 7 cylinder radial engine, using the cylinder heads, pistons, cylinders and several other parts of a VW 1200.
Way cool, but how are the heads/valvetrain oiled?
Beetle1950
About the rockers: indeed they don`t get oil, just like the very early radials.
I put the holes full of grease.
Is your engine 100hp to 150hp?
http://images.thesamba.com/vw/gallery/pix/1188204.jpg
herr_oberst 08-19-2014 01:32 PM
Tough to say how long the stroke is in the vw jugged engine, here's a vid of a different cutaway radial in action:
(which is pretty cool in it's own right!)
<iframe width="640" height="360" src="//www.youtube.com/embed/HGKXdYCksAQ?feature=player_detailpage" frameborder="0" allowfullscreen></iframe>
Tobra 08-19-2014 10:06 PM
De Man indeed!
Exactly so, coolest thing I have seen in a while.
I bet that is a pretty short stroke.
afterburn 549 08-20-2014 04:03 AM
Old school radials had valve trains that needed to be greased every few hours.
Question-
I forgot the reason why -
Why can a radial have only Odd numbers for cylinders ? 3 but not 4, or 7 but not 6 ETC
Mike Billings 08-20-2014 06:17 AM
Here it is:
Four-stroke radials always have an odd number of cylinders per row, so that a consistent every-other-piston firing order can be maintained, providing smooth operation.
Found it here:
https://www.princeton.edu/~achaney/tmve/wiki100k/docs/Radial_engine.html
Interesting question.
targa911S 08-20-2014 08:47 AM
so cool!
