fastfredracing's Avatar
Homemade radial VW engine , beyond cool!!
No left turn un stoned
Old 08-19-2014, 11:57 AM
UnRegistered User
billybek's Avatar
Cool!
Bill K.
Old 08-19-2014, 12:14 PM
I estimated once that there is about 25 HP per VW/356 cylinder, that would make it roughly 175 HP (25 X 7) for the 2.1 L displacement, right?
Does that check out with what they claim?
That propeller would not even clear a cowling cover, I'm guessing they will use something larger in diameter and this one was for static testing/display for start up.
Very cool, very cool.
The design, the engineering, the milling.............quite the accomplishment.
Old 08-19-2014, 12:15 PM
Where did you get that number?
How do they lube the valve train?
Old 08-19-2014, 01:00 PM
wdfifteen's Avatar
Very cool. It's amazing what skilled people with too much time on their hands can do.
I suspect the valve train is lubed through the pushrods like a VW.
I think 25 hp per cylinder is an over estimate. A 912 only makes a little over 100 hp, and this engine isn't tuned like a 912. Oops. 912 has 90 SAE hp.
Old 08-19-2014, 01:08 PM
The rocker shaft assemblies are splash-oiled in a VW engine; the pushrods only supply a tiny amount of oil.
Old 08-19-2014, 01:15 PM
wdfifteen's Avatar
Where does the "splash oil" come from? The pushrods. The rockers are drilled so the oil flows from the cup the pushrod rides in to the rocker shaft.
Old 08-19-2014, 01:17 PM
I based it on the later and higher powered 356's which are just tweaked VW's anyway, sort of.
Right, 4 cylinders X 25 hp ea. = 100 HP total.
Same for a 911 engine more or less, 6 x 25 = 150 hp, similar to as early 2.7's
I did this simplified math for the reason of trying to figure out exhaust muffling, breaking it down per pipe.
Later 911's might be +30 HP per cylinder, early VW's only 10-20 hp.
That's quite a range, but like I said it was for gauging straight through muffler exhaust lengths.
EDIT:
Not the same engine, but interesting.
220 Hp Radial Engine Powered VW Beetle
http://americaloveshorsepower.com/radial-engine-powered-volkswagen-bug/
Built by Continental, the W670-9A engine is rated at 220 horsepower. The engine was used in a variety of applications, and this 1941 model was pulled from an M2 tank. Bore is 5.125 inches with a 4.625-inch stroke, giving the engine total displacement of 668ci. - See more at: http://americaloveshorsepower.com/radial-engine-powered-volkswagen-bug/#sthash.buL80rjL.dpuf
Article on the engine which opened this thread:
http://www.enginelabs.com/news/homegrown-horsepower-radial-engine-constructed-from-vw-parts/
This estimate seems pretty low:
http://jalopnik.com/amazing-loon-built-a-radial-engine-from-vw-parts-1608661285
It seems to be a pretty compact power plant, and if I had to guess I'd say it may make between 80-100 HP? Maybe?
B58/732
BlueSkyJaunte's Avatar
That's freakin' amazing.
Builder: Arnold de Man.
De Man indeed!
ΜΟΛΩΝ ΛΑΒΕ
Old 08-19-2014, 01:21 PM
Band.
The end of the video states it's 2086cc, so it seems like each cylinder displaces quite a bit less than your average VW. Maybe the stroke is shorter?
really cool!
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 08-19-2014, 01:27 PM
Found this thread, many of the same questions being asked: not sure if it is the same engine
TheSamba.com :: View topic - Built: a VW 7 cylinder radial engine!
Beetle1950
Hello,
I made a 7 cylinder radial engine, using the cylinder heads, pistons, cylinders and several other parts of a VW 1200.
Way cool, but how are the heads/valvetrain oiled?
Beetle1950
About the rockers: indeed they don`t get oil, just like the very early radials.
I put the holes full of grease.
Is your engine 100hp to 150hp?
Old 08-19-2014, 01:31 PM
Model Citizen
herr_oberst's Avatar
Tough to say how long the stroke is in the vw jugged engine, here's a vid of a different cutaway radial in action:
(which is pretty cool in it's own right!)
Old 08-19-2014, 01:32 PM
Control Group
Tobra's Avatar
De Man indeed!
Exactly so, coolest thing I have seen in a while.
I bet that is a pretty short stroke.
Old 08-19-2014, 10:06 PM
Air Medal or two
afterburn 549's Avatar
Old school radials had valve trains that needed to be greased every few hours.
Question-
I forgot the reason why -
Why can a radial have only Odd numbers for cylinders ? 3 but not 4, or 7 but not 6 ETC
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 08-20-2014, 04:03 AM
Mike Billings's Avatar
Here it is:
Four-stroke radials always have an odd number of cylinders per row, so that a consistent every-other-piston firing order can be maintained, providing smooth operation.
Found it here:
https://www.princeton.edu/~achaney/tmve/wiki100k/docs/Radial_engine.html
Interesting question.
07 911 Turbo - Pilot Sport Cup 2 ZP
96 Carrera 4 - Toyo R888r
73 911E - Hoosier R7 + twin 75's
92 Corvette - Nitto NT01
14 BMW X3 - Pilot Sport A/S 4
Old 08-20-2014, 06:17 AM
Double Trouble
targa911S's Avatar
so cool!
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 08-20-2014, 08:47 AM
