Gunsmiths - Advise, please.
I'm refurbishing my SKS stock and found this crack.
What's the best way to seal/repair this so that the repair won't show after I stain and seal the stock? . I used a spanner to open the crack to show it better. . Also, is True Oil a good final coat on a stock? . Thanks for any advice. . Edit: Then again, I have boiled linseed oil and maybe I'll try the master's way. . http://www.youtube.com/watch?v=mzVdsln29o8 . ![]() . ![]() .
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View Last edited by Don Ro; 09-01-2014 at 07:18 PM.. Reason: More info...... |
Squirt some super glue gel in there, press it closed tight, wipe off excess.
SKS should be entirely utilitarian. Clear laquer in a rattle can OR applied with a paintbrush. Maybe stain first, depending. For a "correct" finish, it depends on where your SKS was made...
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
Slackerous Maximus
Wood glue, clamp.
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
Don, it's an SKS. You refinish it any way you want and I'll trade you for one w/o cracks.
Jim
down to jap bikes that run and a dead Norton |
Hell Belcho
Wood glue, clamp and sand.
Saved by the buoyancy of citrus. |
Thanks, boys.
It's a Chinese Norinco 56, BTW. So, doing any of the suggested, the bonding agent(s) will take on the stain? . I know, it's not like it's a collector's piece...just am into this and want it to look good. The original finish looked orange-ish and as if it was painted on w/a broom. ![]() All clumpy and full of debris. But damn!, now that it's stripped, this stock is virgin. I'll proceed. .
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View |
I would clamp it first to make sure the crack closes all the way. After that a little superglue (I use the liquid not the gel as it flows a little deeper into the crack) and clamp again until it sets. Either use lacquer or tung oil for the finish.
Neil 87 944S http://guns.claasen.us/ |
Double Trouble
I use this...Buy Satellite City Super T Instant CA Glue, Med, 2 Ounces at Woodcraft.com
or this:Buy Satellite City Hot Stuff Instant CA Glue, Thin, 2 Ounces at Woodcraft.com be careful with it as you cannot feel it on your skin. I glued myself to a stock once. Thank god I had some acetone around. doh!
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base |
Great! Will do. Thanks muchly.
