Fleabit peanut monkey
Bob Kontak's Avatar
Key Fob Battery - When is it dead V wise?
Key fob has a 2032 disc battery. 3V. Puts out 2.92V with VM.
Is she dead wrt the fob functioning?
1981 911SC Targa
Old 09-10-2014, 02:58 PM
Information Junky
island911's Avatar
I can tell you that with my Cayenne keyfob, that the battery has to have higher than normal voltage when the contact has green corrosion. :-/
I've been meaning to write this up for the Cayenne forum, but in short, the contact that grabs the side of the battery is not soldered to the board. (it's a spring contact) This (with a little moisture) allows the contact pad, on the PCB (printed circuit board) to corrode, and add resistance to the path. Then batteries seem to toast quickly. But really, it's this bad contact that is casing problems.
Old 09-10-2014, 03:57 PM
Bob Kontak's Avatar
Thx - spring thingie had broken away and I re-soldered. Gonna go nut up and pay the $5 to check. Back in a bit.
1981 911SC Targa
Old 09-10-2014, 04:33 PM
Bob Kontak's Avatar
Works like a charm.
Thanks for your time island911.
1981 911SC Targa
Old 09-10-2014, 04:59 PM
You do not have permissi
john70t's Avatar
A swipe with WD40 on a rag probably wouldn't hurt.
It helps with sticky outlets as well.
Old 09-10-2014, 09:06 PM
Batteries typically need a load to be tested. Open circuit voltage is not a good indicator.
Old 09-11-2014, 12:09 PM
The total capacity is measured until the battery is at 2 Volts.
http://data.energizer.com/PDFs/cr2032.pdf
Rick
88 Cab
Old 09-11-2014, 08:22 PM
Information Junky
island911's Avatar
Works like a charm.
Glad to help.
Key remotes, they may be expensive, but at least they are fragile. :-/
Old 09-17-2014, 03:33 PM
