-   -   How do I clean a small engine gas tank? (http://forums.pelicanparts.com/off-topic-discussions/832640-how-do-i-clean-small-engine-gas-tank.html)
A930Rocket 10-04-2014 12:05 PM
My edger sat so long it gummed up. A new carb was cheap so I ordered a new one. The gas tank was $75 so I'm cleaning it.
It has black stuff, gunk and slight rust in it. How can I clean it out? Throw some chain or nuts/bolts with water and shake it up?
Ideas?
sketchers356 10-04-2014 12:26 PM
I would think that you would need a solvent like acetone rather than water.
stomachmonkey 10-04-2014 01:17 PM
Acetone or lacquer thinner first then follow with nuts bolts in Kerosene or diesel.
nynor 10-04-2014 01:37 PM
i've had good luck with white vinegar and some dish detergent. it gets all the rust, if you let it sit for a day or so. then the nuts and bolts with kerosene.
Tishabet 10-04-2014 02:41 PM
Lye will do it. For vespas the SOP is a piece of chain, duct tape the entire thing shut, wrap in a towel, duct tape that, then tumble in a dryer for a couple of hours. You can rinse with water, as long as you get the water out of the nooks and crannies with some wd40.
A930Rocket 10-04-2014 05:54 PM
Good ideas. Thanks.
GWN7 10-04-2014 07:06 PM
My neibour duck taped a lawnmower tank to the inside of my electric cement mixer with a couple nuts and washers inside. Put the drive belt on the slowest setting and let it spin for a couple of hours.
