A930Rocket's Avatar
How do I clean a small engine gas tank?
My edger sat so long it gummed up. A new carb was cheap so I ordered a new one. The gas tank was $75 so I'm cleaning it.
It has black stuff, gunk and slight rust in it. How can I clean it out? Throw some chain or nuts/bolts with water and shake it up?
Ideas?
Old 10-04-2014, 12:05 PM
sketchers356's Avatar
I would think that you would need a solvent like acetone rather than water.
Alexander
'75 911S Targa
'86 951 SOLD
Old 10-04-2014, 12:26 PM
The Unsettler
stomachmonkey's Avatar
Acetone or lacquer thinner first then follow with nuts bolts in Kerosene or diesel.
"I want my two dollars"
"Brandon Won"
Old 10-04-2014, 01:17 PM
winter-hater club member
nynor's Avatar
i've had good luck with white vinegar and some dish detergent. it gets all the rust, if you let it sit for a day or so. then the nuts and bolts with kerosene.
"COOL PRIUS!" - Nobody Ever
Old 10-04-2014, 01:37 PM
Feelin' Solexy
Tishabet's Avatar
Lye will do it. For vespas the SOP is a piece of chain, duct tape the entire thing shut, wrap in a towel, duct tape that, then tumble in a dryer for a couple of hours. You can rinse with water, as long as you get the water out of the nooks and crannies with some wd40.
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 10-04-2014, 02:41 PM
A930Rocket's Avatar
Good ideas. Thanks.
Old 10-04-2014, 05:54 PM
GWN7's Avatar
My neibour duck taped a lawnmower tank to the inside of my electric cement mixer with a couple nuts and washers inside. Put the drive belt on the slowest setting and let it spin for a couple of hours.
Bunch of old cars
Old 10-04-2014, 07:06 PM
