The Unsettler
stomachmonkey's Avatar
When the box gets sluggish check for Spotlight indexing. Easiest way is to hit the magnifying glass upper right in the menu.
If not run Activity monitor, sort by %CPU, see if you have a process that's being a pig.
Not a lot of difference between Parallels and Fusion. They've both been around long enough where sometimes a version of one is better than the other.
Years ago I used Parallels but there were a couple of crappy versions and I switched to Fusion.
Currently Parrallels has the advantage.
VM Benchmarks - Parallels 10 vs. Fusion 7 vs. VirtualBox
"I want my two dollars"
"Brandon Won"
Old 11-17-2014, 05:17 AM
Shaun @ Tru6's Avatar
I've done the Activity Monitor thing, shows nothing, no hogging. I'll look at Spotlight next time it happens, thanks.
Tru6 Restoration & Design
Old 11-17-2014, 05:46 AM
