I like Numbers better anyway. Excel is pretty robust but I find Numbers more intuitive and easier on the eyes. Far easier to tweak the look of too.
I have to say the Air is the best laptop I've ever bought. I'm out of space so I think I'll buy another newer one. Unix, Mac OS and when I need it Parallels.
Got way too many devices but I can akways use more :) Been through a lot of PC's and laptops but my Apple products always and still work. Still have a working SE/30 and Newton :D |
rjp |
Something I don't like about Macs is that they have two names for their OS. One app says it needs OS 10.9 and another says it needs Mavericks. I'm constantly looking up which number relates to which name because I can't ever remember. Is their any good reason for this?
This talk of upgrading the mac book has me taking notice.
where do I look in the computer to check hard drive and ram? |
Depending on which version of the OS it'll be either "More Info" or "System Report" RAM and hard drive are in the Hardware category. RAM is obvious, Memory Hard drive depends on the machine, either under ATA or SATA. Look for Rotational Speed. It'll be either 5400 or 7200. If a much older box could even be 4800. |
Here is what I have.
Model Name: MacBook Pro Model Identifier: MacBookPro6,2 Processor Name: Intel Core i5 Processor Speed: 2.53 GHz Number of Processors: 1 Total Number of Cores: 2 L2 Cache (per Core): 256 KB L3 Cache: 3 MB Memory: 4 GB Processor Interconnect Speed: 4.8 GT/s Boot ROM Version: MBP61.0057.B0F SMC Version (system): 1.58f17 Serial Number (system): W8015V2ZAGV Hardware UUID: 94F7F446-9324-5DB0-8DCB-7FF70AD29684 Sudden Motion Sensor: State: Enabled 5400 rotational under Serial ATA Intel 5 Series Chipset: Vendor: Intel Product: 5 Series Chipset Link Speed: 3 Gigabit Negotiated Link Speed: 1.5 Gigabit Description: AHCI Version 1.30 Supported Hitachi HTS545050B9SA02: Capacity: 500.11 GB (500,107,862,016 bytes) Model: Hitachi HTS545050B9SA02 Revision: PB4AC60W Serial Number: 101126PBL400M7GMKP0V Native Command Queuing: Yes Queue Depth: 32 Removable Media: No Detachable Drive: No BSD Name: disk0 Rotational Rate: 5400 Medium Type: Rotational Partition Map Type: GPT (GUID Partition Table) S.M.A.R.T. status: Failing Volumes: disk0s1: Capacity: 209.7 MB (209,715,200 bytes) BSD Name: disk0s1 Content: EFI Macintosh HD: Capacity: 499.25 GB (499,248,103,424 bytes) Available: 110.68 GB (110,677,479,424 bytes) Writable: Yes File System: Journaled HFS+ BSD Name: disk0s2 Mount Point: / Content: Apple_HFS Recovery HD: Capacity: 650 MB (650,002,432 bytes) BSD Name: disk0s3 Content: Apple_Boot |
nuthin outlandish. 2011 MBP13" Best computer I've ever owned and the first time in my life I'm not itching to upgrade after a few years. I'm attached to this thing like my right arm.
Model Name: MacBook Pro Model Identifier: MacBookPro8,1 Processor Name: Intel Core i5 Processor Speed: 2.3 GHz Number of Processors: 1 Total Number of Cores: 2 L2 Cache (per Core): 256 KB L3 Cache: 3 MB Memory: 4 GB Boot ROM Version: MBP81.0047.B27 SMC Version (system): 1.68f99 Serial Number (system): C02FJ553DH2L Hardware UUID: E5021AB5-C345-546E-8A71-50D5BBAB85DB Sudden Motion Sensor: State: Enabled |
I would do full back up ASAP. That box will take 8 GB RAM max. |
Man, I need to step up & go to the Dark Side...
I felt the same way when I got my first Macbook in 2011. Never have things been so easy. Still running strong with no issues, even after years of continuous use.
A 2011 MacBook Pro can take 16 GB of RAM, not just 8 GB like Apple's literature claims. Ask me how I know. ;)
Chocolatelabs is mid 2010. He needs to address that hard drive issue. As long as he's in there may as well do the RAM. |
Back it all up throw more ram in it and add an ssd, and you will feel like you just bought a new computer...
When I look at the drive section there are 2 chip sets. Below is the other. Maybe its the original. I have replaced this hard drive once. Backing up now. ntel 5 Series Chipset: Vendor: Intel Product: 5 Series Chipset Link Speed: 3 Gigabit Negotiated Link Speed: 1.5 Gigabit Description: AHCI Version 1.30 Supported MAT****ADVD-R UJ-898: Model: MAT****ADVD-R UJ-898 Revision: HC09 Serial Number: UJ92 1258R2 Native Command Queuing: No Detachable Drive: No Power Off: Yes Async Notification: No |
where you guys getting the best deal on power bricks? I'm down to only one- the pins always fail- they go flat....
| All times are GMT -8. The time now is 08:35 PM. |
