Bill is Dead.
cashflyer's Avatar
DVR drive replacement
At my shop, the 8ch security DVR is reporting a drive failure.
Is the OS on units like this contained completely on the board, thus allowing me to just plug in another drive? Or does the drive need to have an operating system on it?
Old 11-20-2014, 09:41 AM
Depends on the drives.
I remember when I upgraded a Tivo drive, you had to use a special program outside of Windows. If you cloned the drive in Windows, it would do something to the partition table with extra info that would prevent it from working. This is about 10 years ago, but I would Google your particular model and see if there is any info out there, or call their support line.
Neil
'73 911S targa
Old 11-20-2014, 11:18 AM
Bill is Dead.
cashflyer's Avatar
I tried their support line first.
They said that model is no longer supported and I would have to buy a new system.
Many of these security DVRs are sold with no hard-drive installed, allowing the purchaser to install a drive themselves. This is why I was thinking it was simply a "plug and play" affair.
I've been reading over this site. Though it is a different brand, I am hoping my unit will be a similar job.
http://www.cctvcamerapros.com/DVR-Hard-Drive-Installation-s/218.htm
Old 11-20-2014, 11:33 AM
least common denominator
scottmandue's Avatar
Say it ain't so!
Hard drives are pretty cheap... worth a try... and if it doesn't work you could add the drive a PC as a second drive.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 11-20-2014, 12:44 PM
Band.
Open it up, and you'll find out. I bet the drive in there is a run-o-the mill Best Buy SATA, depending on how old the system is.
The only thing that might be a little challenge is formatting it properly, if the machine won't format it for you.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 11-20-2014, 12:58 PM
Bill is Dead.
cashflyer's Avatar
It's a Seagate SATA/300, 1tb. Yep, not real expensive. Certainly cheaper than buying a whole new DVR system like the 'customer service' rep suggested.
Old 11-20-2014, 01:25 PM
Aragorn's Avatar
Tivo drives had to be "blessed" "Bless" 'B' Drive And Expand Backup 'A' Drive - Getting The Most Out Of Your TiVo
Do a google search on your system by model number and see if it needs some kind of special program or procedure for changing the hard drive.
bunch of random cars and bikes.
Old 11-20-2014, 01:40 PM
