dimmable led bulbs that don't buzz?
Anyone had any luck getting a dimmable led bulb that doesn't buzz?
I've got a couple, and if you screw them into a socket that is not controlled by a dimmer, they are quiet as a church mouse. As soon as you relocate them into a socket controlled by a dimmer, they buzz like a vibrator on a formica table. I guess I'll end up getting CFL. I've recently gotten a few of the 10w leds that seem to work really well as a light bulb as long as they aren't screwed into a socket that's controlled by a dimmer. And since we've got 6 bulbs in our bathroom, I'd like to swap to a cfl or led. I've considered moving the dimmer to another socket, and may end up doing that.
Monkey+Football
Which brands? I want to make a switch in a couple of high traffic locations in the house and want to know what you've had good/bad experiences.
<Insert witty comment> 85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff. |
I've ordered 4 different bulbs to see what I thought of each.
I think this is my favorite, and is not dimmable. It's the most like a regular light bulb http://www.amazon.com/gp/product/B00EUAQ5UA/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1 Philips 429381 10.5-watt (60-watt equivalent) 800 Lumens 3000K A19 LED Household Light Bulb, Bright White This one also works well and is dimmable. It works well in our ceiling fan because there's limited space, but you wouldn't want it exposed because it doesn't look like a regular bulb. http://www.amazon.com/gp/product/B00I134ORI/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1 Philips 433227 10.5-watt Slim Style Dimmable A19 LED Light Bulb, Soft White this one is dimmable, but has the buzz. It seems to work pretty well, but if you look at the very top, when it's lit, it's got a dark area. It's only an issue if the bulb is in an exposed socket like a downlight or something and you can see the end of the bulb. http://www.amazon.com/gp/product/B00BYG7O8A/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1 Cree 9.5-Watt (60W) Soft/Warm White (2700K) LED Light Bulb I've had good experience with a Cree branded light for standard recessed lights in the past that I got at HD. Actually, they were recommended by someone here on the board. They came on instantly, had good light quality and looked good. Would NOT recommend this one. I tried the "daylight" option and don't like the color of the light (they had regular color, I wanted to try the daylight), but for me the big problem is that when you turn the bulb on, it takes a fraction of a second to come on. That doesn't sound like that big a deal, but it's definitely something that I don't like in a light bulb. http://www.amazon.com/gp/product/B0073COMUW/ref=oh_aui_detailpage_o07_s01?ie=UTF8&psc=1 LE 10 Watt A19 E27 LED Bulb, 60 Watt Incandescent Bulbs Replacement, 830lm, Samsung chip LED, Daylight White
Banned
3m
It'll be legen-waitforit
Not bulbs but i finally found strips with a convertable that was magnetically dim-able Took me a while, but glad i found them.
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
Steve,
All those LED lamps are entry level products and the drivers are not that adaptable. I can research a little tomorrow for you but try going directly to the manufactures website to see which type of dimmer they suggest or require. Lutron makes a "CL" dimmer that is made for Edison base LED retrofit lamps that should kill the buzzing. You can find them at Home Depot or online. I Could send you one to try also. Pass & Seymour makes an adaptive dimmer that I have great success with when others have come up short. It is a premium in the cost department. If interested I can post specs tomorrow when I am in the office and have all the info in front of me. This is basically what I do most days by the way, find the best compatibility of LED product and controls to work in different new and retrofit applications for both residential and commercial projects.
Dan Byers |
You need a digital dimmer. And not all digital dimmers like all LED lights, sometimes it takes a couple shots.
I have the Philips L Prize bulbs and a Lutron dimmer, possibly the CL type DByers mentioned, it was about $50 vs. $20-30 for the others that claim to be LED compatible but buzzed. Has to do with reducing the amperage vs. the voltage I think (or the other way around?)
Rob 1980 SC - 2011 Tiguan - 2018 Tesla M3P |
-The Mikester I heart Boobies |
Try this Luton site for more info and to use their LED selection tool. Not all LED's will work with an electronic dimmer. Some want a MLV, some a forward phase and some a reverse phase dimmer. Some will dim but only to a certain point and many will say they dim but really won't. The driver is the weak point in this equation and tends to be the one place that manufacures will use what ever is cheapest and available.
Dimming CFLs and LEDs
Dan Byers |
Banned
im serious, 3M: Dimmer Compatibility
It's difficult with leds. In the end I went to a store that only sells lighting. Talked to a very knowledgeable guy and ordered what he told me to order. Will advise how that went once the stuff arrives next week.
I have been installing these for a good part of the last few years and had no problems. Damn good lights. Its a few bucks more, but worth it imo. Call them and they will walk you through the dimming process. Lutron dimmers are one of the better switches out there.
oops, here's the link Homepage | Rayon Lighting Group
Gorilla
If you check the dimmer mfg websites, they usually have a list of "approved bulbs" or bulbs that have been tested and found to not buzz. The issue with buzzing can be designed out by using higher quality components on the PCB in combination with potting the assembly. Unfortunately, many, if not most aren't potted due to cost, cure times, etc. You may have to try a few different dimmers to get the right combo. Don't give up. If you do, and buy CFLs, good luck dimming them. Check out a company called LEDnovation. It is now defunct but you can still buy inventory of LED light bulbs, pretty inexpensively from places like Grainger.com or 1000bulbs.com. LEDnovation light bulbs are all potted and a significant amount of engineering work went into designing them. They are defunct only because they couldn't compete with the vast supply chains of the big dogs like Philips. PM me if you'd like more information. Last edited by 95avblm3; 12-02-2014 at 03:12 AM.. |
If it helps any, we've had wonderful success with Cree (Ecosmart) recessed and gimbal lighting on Lutron CL dimmers all over the house.
For strip and rope LEDs, I bought the LEDs + drivers from Environmental Lights and they're paired with Lutron magnetic and electronic low voltage dimmers. They work flawlessly. Environmental Lights is in San Diego but they were able to help me figure out what materials were needed and compatible with each other, and I placed the order online.
'87 924S (Sold) |
Eva
I am on the back end of an entire home remodel and have replaced every incandescent with an LED bulb, all FEIT Electric, from Costco at $10 for a 3-pack. I have no buzzing at all but as MysticLlama mentioned, I have replaced all my dimmers. I'm no electrician but that's basic work and I was sure to buy the "LED Compatible switches.
FWIW, if you have recessed can lights, UtiliTech (easily found at Lowes) makes an entire LED can set-up with adapter that screws into the bulb socket, pure plug and play with dramatic improvement in overall light output.
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
thanks guys. This is an apt that we're renting, so I'm not likely to purchase a dimmer to install. It's all very good info, and I may pull the plate off to see what sort of dimmers we have, and then see if they have a preferred bulb. I suspect they're very cheap and not the right kind. I may just end up putting the dimmer in a spot where I won't be using led bulbs.
1966 - 912 - SOLD
Solid State Lighting for Incandescent Replacement
i was too tired to be pretty last night! |
Yep, modern dimmers are needed to go with modern lighting or they will buzz like a chain saw. I had old-school dimmers everywhere in my house and in many cases I just changed them to a switch if I didn't use the dimmer much. My house is now about 1/2 CFL and 1/2 LED with only a few incandescent fixtures left that rarely get used. It's been a 5 year learning curve for me but last month my Edison bill was $38.
![]() 2700k is the magic # for lighting color to pass the wife test.
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) Last edited by Cajundaddy; 12-03-2014 at 08:21 AM.. |
I have never found an LED bulb bright enough to require dimming....
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
