I put a floating turtle trap in one of my ponds several months ago...the type that floats with two rubber bumpers. Caught and relocated over 30 yellow sliders
. Then recently, the trap was caddywhompus, half submerged...something had eaten small holes, 1/8" in one of the bumpers . I filled the holes with caulk, let it harden, and put it back out....now BOTH bumpers have been chewed on....trap was on the bottom. The caulk didn't hold up either....what to use? Don't know which critter is chewing....I also have muskrats, and big azz snapper turtles in the pond...both are suspect....suggestions and ideas please ![]() Nope...I will NOT eliminate the chewers...."live and let live"...within reason.... edited...I went online to the trap's site (Pond King), thinking I might call them....the bumpers are soft vinyl, not rubber if that makes a difference.... Last edited by KFC911; 10-10-2017 at 04:24 AM.. |
Sorry, I only know about rubber baby buggy bumpers.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
funny, I had to look it up too
fenders Could cover them with tight hardware cloth or depending how much time you want o invest use metal tanks/jugs/floats... instead. |
Platinum Member
Duct tape fixes everything.
Then coat with the 'as seen on TV' spray sealer. Kidding..... but serious.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
MBruns for President
fill with expanding closed cell foam
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
After repairing wrap with wire mesh before launching again.
Bunch of old cars
Banned
most all the stuff is open cell and will waterlog in cans from the hardware store
Styrofoam is closed but requires a part-vacuum to expand and is very hard to get in small batches vinyl can be patched with pool toy repair kits but most are thin and do not hold up well just use crabtrap floats they are cheap Styrofoam balls |
Thanks for the suggestions guys....appreciate it!
Not exactly sure what the bumper is you are refereeing to. Is it one of the white vinyl inflatable type? Similar to this type?
![]() If so 3M 5200 will stick and hold to the vinyl. Repair similar to a bike tube. Find something to bridge the gap 5200 around the hole and press the patch into the 5200. Fill as usual. Of course what ever ate through will do it again. I think Jeremy's foam idea is pretty good. Spray the foam in the hole, after it sets use the patch and 5200 to make water resistant. The foam will keep it from sinking again. |
Got any old glass gallon jugs?
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
. I like the foam idea too...been looking online for something I can spray. Gotta keep it light, glass, etc. is out, and I really don't want to enclose the bumpers in a wire mesh....weight and snagging grasses, etc. Thanks all...the search continues...
Platinum Member
Can you replace the floats with something cheaper? Like 4" pvc pipe and endcaps?
The 4" PVC w/ endcaps might work...great suggestion too! |
Just use the foam cans from one of the box stores. has a straw to stick down in the hole.
I think I'll do that, even if it's not closed cell foam, seal the holes, maybe a bit of duct tape too and see what happens...thanks all!
