Wobbly half wall
Redoing a bathroom and adding a half wall that will have glass on top. We constructed the half wall and tied it into the existing framing but the end is wobbly. How does one stiffen up the end not connected to a wall?
Thanks in advance
Old 02-08-2015, 01:58 PM
I would let in a 1 x 4 diagonal, bottom at the wall end and top at the free end.
You could also screw on a piece of plywood.
Is this with the drywall on? you may find that just plating on the drywall gives all the stiffness you need.
Old 02-08-2015, 02:16 PM
As mentioned, above, the wall will stiffen considerably once it is sheathed. Nailing a 3/16" or 1/4" plywood sheet to one side, nailing as if it's outer wall shear panel, will really hold down the wall. Add to that, screwed in drywall to the outside and, I assume, backer board/tile on the inside, and you will have a stable half-wall.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 02-08-2015, 02:27 PM
Banned
Is the flooring underneath stable?
Old 02-08-2015, 02:43 PM
Brew Master
cabmandone's Avatar
The way I did it takes a bit of time but you actually make the front of the wall more like a newel post. I extended the front post down into the floor. Mine was next to a floor joist so I fastened it with lags to the floor joist. If you're further away from a post you could run two boards between your joists to sandwich the post then lag (if that makes sense).
The other thing is, make sure the wall is fastened securely at the back to the existing framing and don't be afraid to go overboard with screws in the bottom fastening it to the floor.
Old 02-08-2015, 02:54 PM
I see you
flatbutt's Avatar
How long is the half wall? I presume that the longer it is the less torque it takes to get it moving. Can you tie the free end to the ceiling with some sort of decorative newel?
Old 02-08-2015, 02:58 PM
this.
Old 02-08-2015, 03:40 PM
On my bathroom half wall about 3' long, I made the bottom frame out of 2"x4"s and then filled in the horizontal space with another 2"x2" so the wall before drywall was 5.5" thick. I then screwed all three 2-bys together and then lag bolted it in 6 places to the two 3/4" thick plywood sub floor.
15 years later, that wall is still holding fast and has seen a lot of slamming doors and leaning people with nary a movement.
Old 02-08-2015, 03:47 PM
We have built lots of them, shear it up cover with drywall or tile. You will be fine. Make sure you put enough nail (every 6-8") to the bottom plate. No more then that or you will rip the bottom plate to pieces.
Old 02-08-2015, 03:56 PM
Take a look at Simpson framing connections. They make a connector for the last stud of your half wall to the flooring below. The issue typically isn't the wall but rather the floor plate to floor below,and then plate to stud connection.
The one I'm thinking off nails/screws to last stud and bolts down into framing below. See them used on half walls in stairwells typically.
Old 02-10-2015, 07:42 AM
HDB/HD Holdowns
Old 02-10-2015, 07:46 AM
