Make Bruins Great Again
There seem to be a lot of opinions out there. What do you think?
Specifically I am wondering if you use snap caps, what brand works well in Glock semi autos?
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Dont think I have, and i've spent months on dime drlls....
dolor et pavor Copyright |
I was always told you needed them for rimfire only. Otherwise the firing pin would/may hit the edge of the chamber. A lot harder than the soft brass of the case.
Who, What, When, Where, Why and How. |
I only use snap caps to cause stoppages.
Place a few random snap caps in your magazines during practice to learn to clear rapidly
" Formerly we suffered from crime. Today we suffer from laws" (55-120) Tacitus |
Yep, not really necessary on a modern center-fire pistol, unless you plan on doing it a LOT. They can be useful to randomly mix in with live rounds to work on clearing malfunctions and/or flinching tendencies.
EDIT: Jim beat me to it.
Nope. I have some but don't use them.
I don't dry fire other people's guns or guns at gun shows. Some people get a bit sensitive about it. . |
I will dry fire a semi after racking the slide to see if it's empty, but never do on fixed firing pin revolvers. Just how I been doing it forever...
Depends upon the spoon. Some are fine to fire without, some require them.
on a glock you need to. after racking the slide to check for emptiness..the firearm, not our souls.
you have to drop the hammer before you can disassemble the thing. but that is relatively FEW dry fires, compared to making PEW PEW PEW sounds with the thing running drills.
poof! gone |
Revolvers I use caps.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
I see you
same here. I do use caps to check myself for anticipation.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Per S&W, the only thing that you shouldn't dry fire is a 22. I assume that's for current models. I don't know that it would apply to a 40 or 50yo handgun. https://www.smith-wesson.com/customer-service/faqs Quote:
When obtaining a new firearm, familiarization to it is key to being effective. If a person doesn't have a lot of access to live fire shooting it seems to me that snap caps is a great way to know the lay of the land before being able to get to the range. It seems like a small price to pay to know that you aren't doing damage to a new Glock and can get a running start on things.
Here's a FAQ from Glock: Quote:
unindicted co-conspirator
Dry fire empty
Snap caps for function testing the ejector/extractor, etc
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution ‘86 928S3 - barn find project car |
Here you go. From Glock: no “pew pew pew” sounds. But you will need to dry fire to slip the slide off.
poof! gone |
^ Yup posted it last night.
It looks like the snap caps are a have to have for rimfires and good to have for a lot of dry fire with a center fire.
I finally looked up snap caps
.... any benefit over just using spent cartridges? Just asking... I've no need to use either.
I have always used spent .22 cases in my .22s.
Not sure about centerfire, never needed to.
From what I've read, the issues with spent casings: it may
-scratch the chamber or -not go in straight and jam -already has a compressed primer and won't cushion properly
The other issue with using a spent case for a dummy (assuming it has a bullet in it to be of any use) is you could mistake a live round for the dummy round
That’s why snap caps are red
