CTEK # 7002 battery charger/maintainer
I'm thinking about buying one of these, seems like it has all the features I would want including the ability to save radio/ECU memory while changing the cars battery. Looks like it will work with all the batteries I have for cars , truck, garden tractor , boat and RV and it can do all types of batteries. Anyone using this particular model ? And any of you using the cigarette lighter adapter ? For the Boxster this is a nice feature because the front trunk light will stay on unless it is latched shut which is not good for the power cord. Or I pull the electrical connector off the light but that's a pain. The cigarette lighter adapter seems like an easy way to get around that .
I use it through the cigarette lighter to keep the 996 topped up. It seems to function quite nicely.
I bought three and gave my daughter one. I keep my 911s on them all the time and occasionally us one to bring my other cars up to 100% if it have been very cold or I have not driven them much. I bought extra wired connectors and wired each car for easy connect/disconnect (like these).
For me, the cords are so thin that I can still close the hood and they feed through the hood gap. I also got an 8ft extension for each that allows me even more flexibility. I can plug the box in, inside the garage (where it is dry and wont be stolen) and close the garage door on the cord with a car outside that I am charging. Our host sells these, but I couldn't seem to get the link/photo to post. I use the lighter or clamp fittings on guests cars or those I have not wired. |
I have had zero problems with my Harbor Freight model. I think they are $5 when they're on sale.
I have four, they all work nicely. |
I have no idea what you're talking about, and there is no photo.
I wouldn't spend money on a cigarette lighter float charger though. If you're going to buy anything, get a smart battery charger. You can get a good Schumacher at Walmart, or go with a pro quality at Napa Auto. They all have float charge mode, can also boost your battery for a start, or charge at 2 amps or 6 amps. And all have automatic shut off. |
Thank you |
If you buy additional connectors, you can choose from 6mm (M6), 8mm (M8) or 10mm (M10) size rings. Might have to shop around:
http://forums.pelicanparts.com/uploa...1425073777.jpg |
I use em on the cars and MCs. Have given some to friends as well. I am usually the one they call when there is a problem so I figure it's a time saver for me.
CTEC makes great products.
I need to get one for my Porsche. Tying to figure out the solution for my bug though. Where I have it stored, there isn't power available. Thinking a disconnect may be my best bet actually.
Depending on how long you store your bug, you might be better off bringing your battery home with you and leaving it on a trickle charger/maintainer like this one..
This time of year maybe a week or two? Over the summer yes it sits for a few months so I can bring it home.
You are right, the disconnect would probably be the best bet for two week or less.
| All times are GMT -8. The time now is 03:23 AM. |
