-   -   Vibration when coasting (http://forums.pelicanparts.com/off-topic-discussions/856504-vibration-when-coasting.html)
Bugsinrugs 03-17-2015 04:29 PM
Does anyone have any idea why when coasting in my 01 tacoma 4x4 I get a weird vibration that I don't feel when the truck is under a load.
I am really at a loss on this.
911boost 03-17-2015 04:32 PM
Rear end, how many miles on the taco?
Pinion bearing?
pete3799 03-17-2015 04:34 PM
The whole truck vibrate or is it coming from the front or rear?
Check for a bad u joint.
Bugsinrugs 03-17-2015 04:37 PM
Replaced the rear end two years ago. Less than ten thousand since replacement.
The truck has around 160,000 miles.
Bugsinrugs 03-17-2015 04:49 PM
I thought u joint also, but there isn't any noise or vibration when I accelerate or decelerate.
I can' t tell if it's front or rear. It seems to be the entire truck. It's not a huge vibration but it is noticeable.
Oh Haha 03-17-2015 04:53 PM
Does it have a 2 piece driveshaft? If so, the carrier bearing may be hosed.
onewhippedpuppy 03-17-2015 05:06 PM
Sounds like a u-joint to me.
Bugsinrugs 03-17-2015 05:43 PM
Two piece drive shaft. I will check the carrier bearing. Thanks all
surflvr911sc 03-17-2015 08:41 PM
Tire(s)?
LWJ 03-17-2015 09:32 PM
Muffler bearing.
john70t 03-17-2015 10:11 PM
Coasting uphill or downhill?
jorian 03-17-2015 10:58 PM
2nd the ujoint diagnosis.
Under load the ujoint will have no free play. No noise.
ckelly78z 03-18-2015 03:55 AM
My F250 4x4 does this if I leave the Warn manual hubs locked in on dry pavement. A slight, but noticable vibration.
Bugsinrugs 03-18-2015 04:56 AM
Originally Posted by LWJ (Post 8535525)
Muffler bearing.
Those were replaced when I serviced the kniticel rod;)
GH85Carrera 03-18-2015 07:30 AM
Wait!
Maybe your wife had the vibrator seats installed and forgot to tell you!
Bugsinrugs 03-18-2015 08:07 AM
It only vibrates when she is coasting. Errr I mean when I am coasting.
ossiblue 03-18-2015 08:31 AM
When you're coasting is exactly when the vibrator is needed!
jabb 03-20-2015 12:44 PM
A Rear tire out of balance can also vibrate the car while coasting
Bugsinrugs 03-20-2015 01:16 PM
Tires to be rebalanced to hopefully eliminate the bad vibe
