Vibration when coasting
Does anyone have any idea why when coasting in my 01 tacoma 4x4 I get a weird vibration that I don't feel when the truck is under a load.
I am really at a loss on this.
Old 03-17-2015, 04:29 PM
Rear end, how many miles on the taco?
Pinion bearing?
Old 03-17-2015, 04:32 PM
pete3799's Avatar
The whole truck vibrate or is it coming from the front or rear?
Check for a bad u joint.
Pete
79 911SC RoW
Old 03-17-2015, 04:34 PM
Replaced the rear end two years ago. Less than ten thousand since replacement.
The truck has around 160,000 miles.
Old 03-17-2015, 04:37 PM
I thought u joint also, but there isn't any noise or vibration when I accelerate or decelerate.
I can' t tell if it's front or rear. It seems to be the entire truck. It's not a huge vibration but it is noticeable.
Old 03-17-2015, 04:49 PM
Oh Haha's Avatar
Does it have a 2 piece driveshaft? If so, the carrier bearing may be hosed.
Pacific Blue
Wayne
Old 03-17-2015, 04:53 PM
Did you get the memo?
onewhippedpuppy's Avatar
Sounds like a u-joint to me.
Old 03-17-2015, 05:06 PM
Two piece drive shaft. I will check the carrier bearing. Thanks all
Old 03-17-2015, 05:43 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
Tire(s)?
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 03-17-2015, 08:41 PM
LWJ LWJ is online now
Muffler bearing.
Old 03-17-2015, 09:32 PM
You do not have permissi
john70t's Avatar
Coasting uphill or downhill?
Old 03-17-2015, 10:11 PM
Registered Cruiser
jorian's Avatar
2nd the ujoint diagnosis.
Under load the ujoint will have no free play. No noise.
Old 03-17-2015, 10:58 PM
My F250 4x4 does this if I leave the Warn manual hubs locked in on dry pavement. A slight, but noticable vibration.
Old 03-18-2015, 03:55 AM
Originally Posted by LWJ View Post
Muffler bearing.
Those were replaced when I serviced the kniticel rod
Old 03-18-2015, 04:56 AM
Wait!
Maybe your wife had the vibrator seats installed and forgot to tell you!
Old 03-18-2015, 07:30 AM
It only vibrates when she is coasting. Errr I mean when I am coasting.
Old 03-18-2015, 08:07 AM
When you're coasting is exactly when the vibrator is needed!
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 03-18-2015, 08:31 AM
jabb's Avatar
A Rear tire out of balance can also vibrate the car while coasting
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 03-20-2015, 12:44 PM
Tires to be rebalanced to hopefully eliminate the bad vibe
Old 03-20-2015, 01:16 PM
