Team California
speeder's Avatar
Building small motorcycle work stations, questions:
I want to build a couple of boxes out of strong plywood and interior framing to use as platforms for working on bikes, maybe 2' off the ground and 2' wide by 6.5' long. The basic box is easy and simple enough but I'd like to have some parts and tool space underneath, (inside the box), and need advice on best way to make them solid yet open.
I've considered taking a jigsaw to the sides and opening up cubby holes or putting supporting pieces from left-right and opening sides, the problem is that the sides would of course be a major structural component that ties the whole box together. My drawing skills haven't improved much since 4th grade but here is a sketch of what I have in mind:
Denis
Old 03-26-2015, 03:31 PM
Team California
speeder's Avatar
Any help appreciated! Thanks.
Denis
Old 03-26-2015, 03:32 PM
varmint's Avatar
like the plan, but for the plywood.
i had something similar. i used 2x4s. couple hooks on the side for straps. space underneath for tools and a hole in the center for draining fluids into the pans. nailed a cheap harbor freight wheel chock to the front. poor mans solution. but worked.
so much better than crawling around on the ground. and could never quite justify the handy bike lift.
Motorcycle Lifts | ATV & Snowmobile Lifts | Truck Tailgates | Handy Industries
1971 R75/5
2003 R1100S
2013 Ural Patrol
2023 R18
Old 03-26-2015, 03:37 PM
motion's Avatar
Denis, I know guys that build and use these types of stands. Why not just get the Harbor Freight motorcycle lift? If you dig around for a coupon, you can pick one up for $299. I have one and love it.
Motorcycle Lift Table, 1000 Lb. Capacity
'95 993 C4 Cabriolet
Bunch of motorcycles
Old 03-26-2015, 03:44 PM
Team California
speeder's Avatar
Thanks, those are some good features. We were thinking of just using regular stands, (pitbull, etc.), to hold the bike up and steady but hooks and a chock are good ideas too. I was going to frame it inside with 2x4s and cover with thick plywood, just want them to be sturdy and not wobble loose. I was going to cover bottoms with cheap carpet maybe so they could be dragged around easily when not being used, maybe not needed(?)
Definitely better than laying on ground, which I'm doing sometimes now.
We already have a bike lift in the space, not a cheap one, though. They are nice but take up lots of space and we have a lot of bikes there. This is a friend's shop and he has probably 7 or 8 bikes in various stages from projects to ready to ride street bikes. He's been generous with letting me use the shop to work on my bike and I want to build him a couple of these boxes for project bikes that will hold the bike plus all of the removed parts in one moveable modular unit plus room for tools. It's not a business, so multiple bike lifts with the attendant technicians is not the picture here.
Denis
Old 03-26-2015, 04:05 PM
I'm with Bill
Rick V's Avatar
Why not just get a couple of rollcarts and bolt them together? They are on wheels have storage under them and you can bolt any kind of attachments/chocks you want
Old 03-26-2015, 04:15 PM
Team California
speeder's Avatar
I thought about something on wheels but decided that I want it a lot sturdier and not moveable while in use. Thanks just the same, I appreciate all feedback on this.
Denis
Old 03-26-2015, 04:33 PM
Team California
speeder's Avatar
This is the cubbyhole idea I had:
Jigsaw an opening like this, maybe on both sides?
Denis
Old 03-26-2015, 04:37 PM
dlockhart's Avatar
A good thread that covers MC work tables. I have several of the break- down style in use. One always travels to the track with me. (see pic in the thread)
Motorcycle Work Table Thread - Triumph675.Net Forums
"The primary contribution of government to this world is to elicit, entrench, enable, and finally to codify the most destructive aspects of the human personality."
Jeffrey Tucker
Old 03-26-2015, 04:52 PM
If you just make the front open, the plywood back will give it a great deal of strength and resist racking, if you make it open on both sides, you'll need to work harder at bracing it.
Rutager West
Old 03-26-2015, 05:12 PM
Kantry Member
oldE's Avatar
Forget the sides.
The wheels on a bike are on the center line, so try it like this:
One piece as a spine with a couple of slots for cross pieces . Put it together with a top, bottom and ends. Add some cleats at the joins for additional strength. Basically, you've built an "I" beam with stiffening ribs. You have storage in both sides and it's lighter than if you built a box with sides and stiffer since the beam is on the center line.
Have fun.
Les
Best
Les
Old 03-26-2015, 05:15 PM
Team California
speeder's Avatar
Awesome ideas in that thread, thanks! Think I might just build one like the first one pictured, super simple and looks really strong!
Denis
Old 03-26-2015, 05:34 PM
varmint's Avatar
i don't remember the dimensions. but i wish i'd built it wider. top heavy with a bike on it. and should have made a better ramp set up. was always tense getting the bikes on and off.
but for something built with dumpster lumber it was pretty good. got to the point where people i barely knew were inviting themselves over to work on their bikes.
1971 R75/5
2003 R1100S
2013 Ural Patrol
2023 R18
Old 03-26-2015, 05:39 PM
Team California
speeder's Avatar
I'm thinking 2' wide and 2' tall, (or slightly shorter). Wider than the wheel stands by a bit with plenty of room for tools and parts on top but doesn't take up excessive room in shop.
Denis
Old 03-26-2015, 05:47 PM
Detached Member
Hugh R's Avatar
This...I have a Sears Version, it doesn't lift as high, but its the way to go, it also has wheels so you can move the bike around.
Old 03-26-2015, 05:48 PM
Control Group
Tobra's Avatar
Seems like if you had even rudimentary skills, you could make something that would be just the ticket for this out of a shopping cart.
I am not advocating that you steal a shopping cart.
I would probably build it out of 2 x 4 wood if I were using wood.
Old 03-26-2015, 08:53 PM
Friend of Warren
Friend of mine made a table using a hospital bed frame. Bought the frame at an auction. Wheels lock it in place.
Kurt V
Old 03-27-2015, 08:20 AM
Team California
speeder's Avatar
That's cool. Clever idea.
Denis
Old 03-27-2015, 09:09 AM
Control Group
Tobra's Avatar
Probably pretty cheap too. Will hold at least 300#, and if it you buy one that works, you can make it go up and down, tilt, whatever.
Old 03-27-2015, 09:22 AM
Registered Cruiser
jorian's Avatar
This thing is pretty cool.
Apex Portable Worktable
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 03-27-2015, 10:09 PM
