Best way to move spoons cross country?
In about a month, I'll be driving from Maryland to Washington. My household goods will be in a Pod (or an ABF U-Pack trailer, which is essentially the same thing). I'm trying to figure out the safest way to transport my spoons cross country -- a shotgun, two ARs, and a couple of handguns.
The apparent options: 1 - Keep them with me, in my car. Up-side: I always know where they are. Down-side: They might get confiscated by some overzealous law enforcement along the way. Also, they take up quite a bit of the limited space in my car. 2 - Put them in the trailer with the rest of my stuff. I believe the trailer will be sealed, and I'll get it back on the other side to remove the seal, so the likelihood of theft or confiscation seems low. But having them out of my direct control makes me nervous. 3 - Ship them to a Washington State FFL. Expensive, but it's the most likely way to get a successful outcome. Thoughts? Who's done this before? What's the Right Answer(tm)? Thanks, Dan
'86 911 (RIP March '05) '17 Subaru CrossTrek '99 911 (Adopt an unloved 996 from your local shelter today!) |
I'm with Bill
Personally I would keep them with me but you said limited space. Insured FFL transport would be my second choice
Electrical problems on a pick-up will do that to a guy- 1990C4S |
Cars & Coffee Killer
I'd keep them with you. Throw a blanket over them if they won't fit in the trunk.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
I'm with Bill
I drove to a friends place a few hours north of here in Maryland in the 911. I had my AR six shotguns a couple of handguns, and a trunk full of ammo. I am sure the Maryland State boys would have had a field day with me if I had gotten pulled over
I recently did much the same, IL to TX and back. I have a FOID and CCL for IL.
Get a decent soft case for your long guns, and a safe for your handguns. Use cable locks to secure the big case in the trunk (or all the way back in an SUV), same for the pistols. Then, don't get pulled over. I see plenty of idiots doing worse than me all the time, and as paranoid as I was about having IL plates, made it home safe and sound "riding dirty" through some pretty notorious areas. Good luck with your move! Last edited by Texlexic; 04-14-2015 at 05:18 PM.. |
Serial Lurker
I would keep them with you. Field strip them and keep the slide, bolt fire control assy etc. in separate areas of the vehicle rendering them inoperable in their traveling condition. Easy to explain to LE, and makes sure you present the appearance of good citizen. Don't answer, but if your home state requires it then it would be best for them to be registered to you.
Does anyone know where the love of god goes when the waves turn the minutes to hours? |
Now in 993 land ...
Check your route and list the states you are traveling through. Go to the WWW and research the transport laws for the states. I think the NRA has a specific page. Put the guns in a condition that meets all states' laws and go on your merry way. People travel with guns in cars all the time.
Putting the guns into the moving container most certainly is illegal. I do not know of any moving company (unless specialized) that accepts firearms. G |
Cool, thanks for the immediate and overwhelming response. I like the idea of pulling the bolt and FCG out; makes everything extra-inoperable to make sure I look like a good upstanding citizen. Also particularly like the idea of not getting pulled over. Virtually all of the horror stories I've heard start with getting pulled over -- tail-light out, speeding, or whatever. I'll figure out the space issues, I guess.
Thanks. ![]() Dan
Yup. That's totes legal in VA, but absolutely against all the rules here in MD. You're allowed to transport your guns between your house, the range, the dealer, a repair shop, or a legitimate hunting site. But if it's out of hunting season and you're going to a friend's house, you're SOL. As I understand my current state's laws, that's a felony with a maximum penalty of 2 years in prison.
There is no reason for a cop to get into your car. Don't leave anything in plain sight and never consent to a search. You'll be fine.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Banned
Disassemble, make sure they are in LOCKED cases, and that you don't have any ammo in the car. Zero. They should be inaccessible as well. I would not transport them in the car if you are taking your 911.
When we moved across country, I let the moving company handle it. No problems. |
What the ?
Keep them with you.
SCWDP 73 1980 SC Harley Davidson Road King 9/11/01 FDNY/343 Never Forget! |
Banned
My MAK-90 had blood all over it and hash marks carved into the stock as if someone was counting off their victims, but the point is, I got it back.
Since you will not be going through New York or New Jersey most of the other states you'll visit should not cause any problems unless you give the troopers a reason to stop you. Remember on COPS they do all the stops because a tail/brake light is out, or a rolling stop or other MINOR issue and then bang. If you plan to stop for the night I would make sure the car/truck you are driving is disabled so it will not run, no matter what or take everything inside with you every night.
I am surprised no one gave any actual references so here are some I had put together for some relatives who were moving a while back. THR TruckVault - Gun Transport Laws by State Cross-country moves with guns, How to do it legally? - Calguns.net https://www.nraila.org/gun-laws.aspx |
Even in those states the police would have no PC for a vehicle search after a stop for a broken tail light. Don't consent and you'll be fine.
Okay, don't anyone get all bent out of shape here....
What color is your skin? If you're white you're likely to have less trouble. That said, there was a thread a while back about a fellow who was legally carrying a concealed weapon in a completely legal fashion. He was coincidentally pulled over. When the officer approached the window (I'm paraphrasing here), with both of his hands in plain sight on top of the steering wheel he said , " I have a firearm on me and am permitted to carry it. What would you like me to do?" By showing respect for the situation, the officer returned the same and did his job. Everyone went home happy. As said, read every law in every state you'll go through and obey them. Including traffic laws. There should be no reason to worry.
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
Dog-faced pony soldier
"Shall not be infringed". God what a crock!
I'd break them down and transport. Bury the cases in the bottom under all your other junk. Don't be stupid and as Rick said, don't ever consent to a search. If you're paranoid or dealing with a particularly nazi-like destination (e.g. D.C., Chicago, Boston, NYC, some parts of Kalifornia) it might be worth shipping FFL insured.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Suggestion: go to the local Guitar Center and find yourself a nice electronic guitar case. With slight modifications, these padded cases make a great discreet rifle and shotgun transport case. Much better than the big black sniper case with big "AR-15" embossed on the cover! IMHO, a trigger lock is a better bet than a field-strip. A person familiar with firearms can always reassemble a gun, but that same person cannot easily take the lock off unless they have the key or know the combination. Keeping your firearms in the trunk or a spot furthest away from the driver is also a good idea. Unless you are planning on stopping at ranges or hunting grounds along the way, I suggest not transporting any ammo on your cross country trip - doing this also minimizes the 'appearance of evil.' If you don't have a CCW, I suggest getting one. (Utah CCW has reciprocity with the most states, and can be obtained remotely.) If you have a CCW, you are better protected under the Firearm Owners' Protection Act of 1986 (FOPA). This comes into play especially in states where there are more strict gun control laws like NJ and NY. IMPORTANT: Having a CCW from a given state does not mean that you will have reciprocity in a state you are travelling through. I am not suggesting that you have a loaded gun attached to your hip while travel from state to state - not all states honor out-of-state CCW's! The CCW will just give you an extra layer of legal protection should the need arise. Let me explain this with an example: In NJ, local gun transport laws are subject to the bias of the local magistrate. In NJ, as in DC, there are strict transport laws (to and from the home and range, home and gun shop, home and hunting grounds, with only reasonable deviation while enroute.) If the range is further than a full tank of gas in my car, I can stop to fuel up. However, I cannot stop to pick up a friend, or buy food along the way. If I have a heart attack and drive to the hospital instead, that may or may not be looked upon as a reasonable deviation. It is the "reasonable deviation" part where a judge's bias comes in. However, if you have a CCW, you are better protected under FOPA, which will put you under federal jurisdiction, which will supersede local jurisdiction. I am probably not explaining this correctly, since I'm not a lawyer - but suffice it to say - having a CCW will give you a little extra protection. -Z-man.
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
Bandwidth AbUser
Great info! I'll need it later this year.
Jim R. |
Bandwidth AbUser
Z, you recommend not transporting spoon-food on the x-country trip. What's a good way to get it to your destination?
Jim R. |
