Whew, finally got it off. Here is the happy lady.
http://forums.pelicanparts.com/uploa...1431531080.jpg |
I crashed my bicycle once when I was probably too drunk to walk, did not get a scratch. Did not even own a 914 then, so I did not even have a good reason to be that drunk, aside from it being a Saturday. Try cutting a ring off someone who has 90 year old skin and get back to me on the using dykes thing. If you crush the ring a little, it will give you a little space because it goes from being circular to oval. |
Thing is those tricks work best when you look them up first, after a short failed attempt... when you try a few times and make the finger mad, you get sausage finger and then all bets are off... I went to a jeweler and he used a special tool as pictured in a previous post. He told me the current trend of exotic materials in rings makes it hard, some metals (forgot if it was titanium or other) cannot be cut at a jewelers and you have to go to a fire station for specialized tools... Stick to soft metals ;-)
How about consuming a diuretic for a few days?
Next time go to jail- they have to take off your jewelry. I bet they are pretty good at this.
Wife said she soaked hand in cool water 15 minutes. Petroleum jelly and a lot of determination. I still have the cutting tool coming from Amazon, let me know if anyone here needs one.
Then after the fact became concerned about how to remove it in the event of an accident... the internet said titanium rings will shatter... that made me feel MUCH better! :D |
Here's a concept….How about maintaining the same body weight as the day you put it on there. Funny how too many potato chips and french fries make a ring shrink.
The ER ring removal tool is simply a slow spinning low torque dremel tool... at least thats what we use...
I've seen rings removed using 2 elastic band methods. A bonus of this is, the eleastic band gets the soap solution well under the ring. There's also a dental floss method...though I've never seen it used for real. Just videos.
Here's method 1: https://www.youtube.com/watch?v=v4ks0-1xLVE Method 2: https://www.youtube.com/watch?v=V2oqLTayIzA |
Somewhere there is an M5 with a nice pry bar sized dent in the firewall just behind the right head. Yeah I got my hand stuck. |
Dental floss (or suture) and ky works every time
Sent from my iPhone using Tapatalk |
My wife tripped on the stair and jammed her hand into railing thus swelling up her finger... so potato chips are not required. ;) |
Sage advise I've never forgotten. Charles |
| All times are GMT -8. The time now is 11:24 AM. |
