bivenator's Avatar
Ring stuck on finger! Removal Help
Wife's wedding ring is stuck on her finger. She has tried butter, olive oil, cold water, windex!?, called jewelers and they won't do it because of liability reasons. They suggested the ER or fire department. Both are a bit extreme and we don't want to ruin the ring, so I humbly seek some knowledge from the Pelicans?
the unexamined life is not worth living, unless you are reading posts by goofballs-Socrates
88 coupe
Old 05-12-2015, 02:20 PM
Brando
quattrorunner's Avatar
Try another jeweler
Turbo powa!
1977 911s. it's cool
Old 05-12-2015, 02:24 PM
Moses's Avatar
Old 05-12-2015, 02:26 PM
craigster59's Avatar
Go to the fire station. Perhaps their EMT's have a ring cutter. You'll have to have a jeweler re solder.
least common denominator
scottmandue's Avatar
There is a trick with a thread... I will see if I can find it on youtube.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 05-12-2015, 02:27 PM
I appear to have been usurped!
I took a pair of diagonal cutters and just snipped off a soft silver ring once with no damage to myself.
Gary Fisher 29er
1995 Miata Sold
1984 944 Sold
Old 05-12-2015, 02:44 PM
bivenator's Avatar
She said she had tried the dental floss method last nite but did have any luck. When I get in we will give it another try. I hope it doesn't look like the finger in the picture.
One an unrelated story, as children, her sister put a jelly glass and on her mouth and created a strong suction. They were watching a monster movie about a mad scientist whose experiments transform his face. When she popped the glass from her face her lips were a huge purple piece of meat. We still laugh at that story today.
88 coupe
Old 05-12-2015, 02:46 PM
Use a little ice to numb the finger, and then bolt cutters right below the joint. It'll come right off. A hatchet will work, but if you aren't real careful, it could free up more tham one ring.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 05-12-2015, 02:53 PM
and girls still do this to get..
Ang. Jolie like lips...
Fire dept. should have one of those ring -cutters..(free)
I do..
the ER guys will charge you..
don't wait to long..
circulation is important..
Kantry Member
oldE's Avatar
Number 1: Removal attempt should be in the morning for minimum swelling. (Our hands swell through the day. Evening is the hardest time to remove a ring)
Number 2: Hold the hand over the head for at least a minute before trying to remove the ring. Again, this minimizes fluid build up in the finger.
The trick with the thread involves threading an end of string under the ring, then starting just below the ring with the long end, wrap the finger with the string to compress the flesh. Then take the end left sticking out above the ring, unwind the string, forcing the ring down and off the finger as you go.
Use a lube while you're at it.
Best
Les
Best
Les
Old 05-12-2015, 03:14 PM
Best
Les
I've heard the opposite for shoes, never buy in the morning. I can tell you that my rings go on and come off with more difficulty first thing in the morning.
Old 05-12-2015, 03:31 PM
Targa, Panamera Turbo
M.D. Holloway's Avatar
Coconut oil. It's life changing.
Michael D. Holloway
https://5thorderindustry.com/
Old 05-12-2015, 03:34 PM
Andrew Gawers' Dad
CHICKS's Avatar
ahahaha
Old 05-12-2015, 04:15 PM
RETIRED
Joe Bob's Avatar
Ice water....did wonders to the fat guy's Johnson on Seinfeld....
2012 ML350 3.0 Turbo Diesel
Old 05-12-2015, 04:24 PM
I had to cut my own ring off when it got smashed at work. A pair of sidecuts works well (no fees involved), and the jeweler was able to fix it like new for a fee.
Old 05-12-2015, 04:28 PM
Unregistered
sammyg2's Avatar
Soak it in cider
(say it fast)
oh wait, it's her ring. Never mind, it only works if it's your ring.
or does it .......
You're disgusting, get your mind out of the gutter. Why don't you get yours.
Shut up. you shut up. I'm telling.
And then it got weird
Old 05-12-2015, 04:29 PM
Bill is Dead.
cashflyer's Avatar
Send her to a bar on ladies night with male strippers.
The ring will be off after the first couple drinks.
Old 05-12-2015, 04:30 PM
This will get it off. My friend manufactures it. The number one lube among (oh, never mind).....
Old 05-12-2015, 04:31 PM
Unregistered
sammyg2's Avatar
ewwwwww
Old 05-12-2015, 04:45 PM
pete3799's Avatar
I took a ring off my finger once............kind of miss that finger.
Pete
79 911SC RoW
Old 05-12-2015, 04:47 PM
