Targa, Panamera Turbo
M.D. Holloway's Avatar
Need an Excel Guru
I have a parsing (sp) challenge with an Excel spreadsheet. Any gurus out there?
Michael D. Holloway
https://5thorderindustry.com/
Old 12-04-2015, 05:44 PM
No guru, but what is the issue ?
Old 12-04-2015, 07:44 PM
essentially I have a spread sheet (many) that has data arranged a certain way. I need various cells to be in a very different format. The best way I can explain it is to show you. Can I shoot you two spread sheets? One of the data I have and the other of the data table that needs to be populated?
Michael D. Holloway
Old 12-04-2015, 07:47 PM
Say the data I have is defined in column A and the values are in B, C, D, E.... Bit I need the data to be in Rows. So lets say column B row 5 data has to be in Row 8 Column C. The data in the rows has to parse to the date of the other spread sheet columns.
Michael D. Holloway
Old 12-04-2015, 07:51 PM
I know it can be down. I remember in grad school with a very old version I did macros to do something like this. It must be simpler now. I just never mess with it.
Michael D. Holloway
Old 12-04-2015, 07:53 PM
pm sent
didn't get it
Michael D. Holloway
Old 12-04-2015, 07:56 PM
Please post the solution! I do all my data manipulations for excel in R, but always interested in how people solve data problems
1982 911 Targa, 3.0L ROW with Webers
Old 12-04-2015, 07:59 PM
Boy, if I can't figure out an email, then it's hopeless to help with your spreadsheet.
Pm, tried again.
Old 12-04-2015, 08:07 PM
I sent you one of my email.
Michael D. Holloway
Old 12-04-2015, 08:10 PM
beancounter
jwasbury's Avatar
Vlookup, lookup formula or sumif formula can be pretty powerful tools. Not sure if these will work for your situation.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 12-04-2015, 08:58 PM
ok, may be this will help. I want cell B5 in spreadsheet 1 to fill in C8 in spread sheet 2.
Michael D. Holloway
Old 12-04-2015, 09:26 PM
Paco Anton's Avatar
Send a message via Yahoo to Paco Anton
I love Excel.
That said, for those cases I usually do some kind of labelling. I create an intermediate table that contains the rearrangement instructions (like a label for each data position) and then I create formulas in the final table that populate it with the data from table 1 using the instructions from table 2. This way it is easier to troubleshoot.
If you can share your problem I'd love to give it a go.
Paco Anton
83 SC Targa (Euro)
Old 12-05-2015, 12:58 AM
fred cook's Avatar
You should be able to use a nested conditional formula to populate the necessary fields. For example, you can have it first look for the correct date and then go to the data field for info. You can even have the nested formula look thru an entire spreadsheet, find all the matching data and have it summed in the appropriate field.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 12-05-2015, 05:01 AM
Just thinking out loud
mattdavis11's Avatar
I'm no expert, but the pivot table function in excel could be the answer.
91 FJ80
84 Ram Charger (now gone)
Old 12-05-2015, 06:37 AM
If you haven't found a solution yet, I'm happy to help...I work with crazy complex excel sheets all day long.
1957 Speedster, 1965 356SC, 1965 356SC Outlaw, 1972 911T, 1998 993 C2S, 2018 Targa 4 GTS, 2014 Cayenne S, 2016 Boxster Spyder, 2019 Tacoma
Old 12-05-2015, 06:47 AM
MBAtarga's Avatar
Same here Mike. Send me the file and what you want and I can take a look at it.
Send it to MBAtarga at gmail dot com.
Mark
'83 SC Targa - since 5/5/2001
Old 12-05-2015, 07:25 AM
Is this what you are trying to do?
I'm no guru, but what you described can be done as follows. My version is Excel Professional 2010. Open your Spreadsheet1. Open your Spreadsheet2. To make things easily visible, click the 'View' button, then 'Arrange All', then 'Vertical' so that you can see your two open spreadsheets side-by-side. Now, in Spreadsheet2, go to cell C8. Type the equals sign "=", then click on cell B5 in Spreadsheet1. Hit enter, and the contents of B5 in Spreadsheet1 will populate into cell C8 of Spreadsheet2.
The formula in C8 of Spreadsheet2 will look like this: =+[Spreadsheet2]Sheet1!$B$5
Old 12-05-2015, 06:40 PM
MBAtarga's Avatar
Mike - I just sent you an example for a solution. It was sent back from my home email - different that the above.
Mark
Mark
Old 12-06-2015, 09:38 AM
Regenerated User
72doug2,2S's Avatar
Please post a screen shot of the data now and what it needs to be. Also state the criteria for what you are going to do. Please also indicate the Excel version you are using.
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law.
'72 911T 2,2S motor
'76 BMW 2002
Old 12-06-2015, 12:36 PM
