Banned
computer switch front panel not the P/S switch?
computer start switch
I have a 2-3 year old lenovo [IBM] i7 mini box
we had a power spike from a local lighting strike
the box was OFF but plugged in to a power strip with a surge suppressor
odd thing is the box was working right after
but the ATT universe box blew so no net or tv
so I tryed the power supply but no luck
then tryed a spare P/S no result no fan no lights no beep
but then tryed the paper clip test and the P/S spins it's fan
as does the other P/S but not in the computer
so now I am suppecting the tiny switch on the front panel
problem is the extra switch only has two wires while the IBM box's switch has jumpers
to the other pins 4 wire total and the plug on the other end is very different wire count and positions
so my question is why does the IBM units switch have jumpers ?
what do they do
both switches look the same 1/4'' square plastic and should swap
but one has 6 pins but two wires
the IBM unit has 4 wires to 4 pins
help !!!!!!!!
Old 07-02-2015, 04:08 PM
Scott R's Avatar
More likely the system board. Sorry to be a pessimist but surge protectors are not much good against lightning strikes. If you really want to eliminate the switch jumper the 24 pin connector while it's connect to the main board.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-02-2015, 06:40 PM
