Banned
computer switch front panel not the P/S switch?
computer start switch
I have a 2-3 year old lenovo [IBM] i7 mini box we had a power spike from a local lighting strike the box was OFF but plugged in to a power strip with a surge suppressor odd thing is the box was working right after but the ATT universe box blew so no net or tv so I tryed the power supply but no luck then tryed a spare P/S no result no fan no lights no beep but then tryed the paper clip test and the P/S spins it's fan as does the other P/S but not in the computer so now I am suppecting the tiny switch on the front panel problem is the extra switch only has two wires while the IBM box's switch has jumpers to the other pins 4 wire total and the plug on the other end is very different wire count and positions so my question is why does the IBM units switch have jumpers ? what do they do both switches look the same 1/4'' square plastic and should swap but one has 6 pins but two wires the IBM unit has 4 wires to 4 pins help !!!!!!!! |
More likely the system board. Sorry to be a pessimist but surge protectors are not much good against lightning strikes. If you really want to eliminate the switch jumper the 24 pin connector while it's connect to the main board.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Thread Tools | |
Rate This Thread | |
