LinkBack | Thread Tools | Rate Thread |
up-fixing der car(ma)
WAY OT: Can anyone tell me how to reinstall Windows XP on a Dell 4300?
Well, my (fairly new) comp. is letting go this evening, and I can't get the Dell people...please help!
Scott Kinder kindersport @ gmail.com |
I'd get the computer to boot off the cd ( with xp disk installed) and then re-install windows. If its a dell, it may have XP already on a partitioned area of your hard drive. if so , it eill likely give you a hit f6 to enter setup or rescue of some sort.
You may lose files on your disk, so I hope you have backed up anything important!
1970 911 t (sold) 1985 MR2 (sold) 2011 GT 5.0 2007 CRV |
Do you want to reformat the hard drive?
Have you tried system restore? What particular problems are you having? If you want to reinstall windows, just put the Windows CD in the hard drive and let the CD boot the computer. Then follow the instructions. If you give us more details, I am sure we can all help.
Neil '73 911S targa |
Senior Member
Some versions of the Dell laptops have a CD and some have a CD and a boot disk. Look into your stuff that you got with the laptop and see which one they sent you.
Usually its a bootable CD and you can do as Reg suggested, otherwise you may have to put a floppy in the drive along with the CD and reboot. Dell has the best product support in the business. Cannot understand that they are not helping you with this. I used to work with them (and my current company works with them now)and they stress that if a customer is not being taken care of, move them up the line and I would ask for a supervisor. Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Yes, I booted it from a CD first and after it had finished copying the files to the hard drive, then I just let it go and it completed the installation. Back online, as you can see. Thanks for your help.
Senior Member
If you want to do it right, partition the hard drive into at least two drives. Then store your documents and such on the "D" drive and when and if the OS pukes you can still format or restore the OS and hopefully keep your data.
Joe
Don't know if they still do this on XP machines, but Dell used to put a hidden batch file in the root called "zztop.bat". If you ran zztop from the command line, it brought back an original factory configuration from other hidden image files.
Sounds like you are back in business though.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
