-   -   Cutting down tree (http://forums.pelicanparts.com/off-topic-discussions/871541-cutting-down-tree.html)
Aggie93 06-21-2015 08:53 AM
Cutting down tree
Had a storm come though last week that took down a tree from about half way up. I'm guessing about 25-30 feet remain standing. There are several other trees around it, but few structures. A shed that is protected by other trees and a gazebo, that I think is too far away, plus another tree would block it. Assuming I'm remotely close in getting it to fall the right way. My chainsaw skills are limited to trees already on the ground.
There are some branches only on one side. They are not very big, but still worried they will alter the direction.
Is this something I should be able to do, or call someone.
http://forums.pelicanparts.com/uploa...1434901956.jpg
http://forums.pelicanparts.com/uploa...1434901975.jpg
http://forums.pelicanparts.com/uploa...1434901994.jpg
84CAB 06-21-2015 09:04 AM
Since you had to ask the question if you should do it or not...
Pay someone else to do it. I am an avid DIY'er but things like this can go bad quickly and are unforgiving. I had an uncle that cut trees down for a living but had one bounce off another tree one day and it didn't end well at all.
Probably only cost a couple hundo bucks for someone to drop it while you enjoy a beverage and watch.
recycled sixtie 06-21-2015 09:09 AM
I used to cut down trees when they were smaller and I was younger. If you have experience, the right equipment such as a harness then okay. If you have any doubt about it get it professionally done. If you are not sure your heart will be in your mouth and things can go terribly wrong such as hurting yourself or damage to property(I have done the latter).
You might get lucky and things go okay. But on the other hand for peace of mind get a couple of quotes(referrals?) and hire somebody(insured). Life for me is too short to take these kind of chances. Should not be too much money.
pavulon 06-21-2015 09:09 AM
You should be able to do it. Get a long rope and a buddy to pull into desired fall line, notch cut from desired direction while buddy pulls on rope, cut 180 degrees from notch, move out of way when it cracks.
Do you have a will? :)
LakeCleElum 06-21-2015 09:44 AM
I've cut down a lot of trees in 45 yrs of heating with firewood. This tree concerns me for 2 reasons: 1}. Look at the bends it makes, won't end up where you want it. 2) It is dead and rotten, the top could take you out while cutting, hire it, we have a retired logger that only charges 70 bux\hr
Baz 06-21-2015 09:45 AM
I'd leave it alone to rot away on it's own.....
Mo_Gearhead 06-21-2015 10:02 AM
Those small branches will not have any effect --IF you cut your notches correctly and drop it between the surrounding trees ..as you have indicated. Even if you are off slightly, the weight of the trunk will power those small limbs through any nearby branches it encounters.
Wish I was close. I could have had it on the ground in about as much time as it took to type this.
CUT precisely and then GET AWAY! :)
Gretch 06-21-2015 10:02 AM
If you do not know how to fell a tree, using wedges to make it fall where you want it....... Do yourself a favor and pay a licensed and insured contractor to do it.
Evans, Marv 06-21-2015 10:21 AM
Looks like a very simple job, but you also seem to be pretty unsure. If you don't feel right about it, I agree you should just get someone with experience to fell it.
KFC911 06-21-2015 11:06 AM
^^^^ This...just let a "pro" (or someone else with more experience) drop it for you, then have at it yourself. Shouldn't cost much at all for just a few minutes work for a veteran...YMMV.
rfuerst911sc 06-21-2015 11:30 AM
The pics may be deceiving but that doesn't look like a very big tree. Cut a notch about 18-24 " from the ground, cut the notch where you want the tree to fall. Cut the notch about 1/3rd of the way in. Then come to the back side of the tree and do a back cut 2 " or so above the front cut. This acts as a hinge as the tree starts to fall. As soon as you see movement or hear cracking back out of there and watch where the tree is going. Looks like you have a lot of trees there how else you going to learn ?
vash 06-21-2015 11:53 AM
that one looks fairly safe. cut a felling notch in the direction you want it to go..and do the backcut. wham!! looks like you have room for some error.
i kinda think the real danger is when the thing is on the ground. all those branches bent over with all the kinetic energy. that's the hidden danger. but that tree looks pretty tidy all the way up.
make everyone stay inside, lock up the pets. go for it!!
that looks like the prefect candidate for chopping down with an AXE!! jus sayin.
GWN7 06-21-2015 12:41 PM
Rope, come-along to another tree, go for it. Worst you can do is hit another tree.
GWN7 06-21-2015 01:06 PM
Here's one I did last Sunday. Had to drop it inside the yard and not damage the fence. Trimmed off the branches to control the rotation of the main trunk. Taking the weight off one side causes it to rotate either left or right.
http://forums.pelicanparts.com/uploa...1434916831.jpg
And here's how it ended up....
http://forums.pelicanparts.com/uploa...1434917070.jpg
No damage except to my chipper when one of the hammers broke.
LEAKYSEALS951 06-21-2015 01:16 PM
I stayed at a hotel 8 last night:
http://forums.pelicanparts.com/uploa...1434917663.jpg
tabs 06-21-2015 01:49 PM
Let us say a little prayer for the fallen!
recycled sixtie 06-21-2015 02:09 PM
Whatever you decide I am rooting for you....
Bill Douglas 06-21-2015 02:13 PM
Where's that .gif of the tree falling between the house and the shed, when you need it.
I would wait until the wind is blowing hard in the direction that you want the the to fall in then do the carefully cut notch in the trunk method.
Aggie93 06-21-2015 02:18 PM
I'm unsure only because I've never done it and I know it could go south quickly without any way to stop it.
The possibility of property collateral damage is very small and frankly, I've love to get rid of the gazebo, but even if it fell on it, I don't think it would do much damage. Frankly, I'd love to get rid of it. (previous owners put it up. It replaced a half-pipe they had while their kids were young.). If it fell where where the 2c bet is above, that would be fine. Everything is far enough away.
I think I'm leaning toward calling someone. That way they can all off the wood. I'd like to do it myself mainly because I like learning. And for felling a tree, this seems to have more room for error than most. I have a few emails to some friends to see if they have done this before. Safety in numbers, right? I had other crap to do today. I'll report back when it is down.
LEAKYSEALS951 06-21-2015 05:24 PM
Watch this video 3 times and grab a chainsaw:
<iframe width="560" height="315" src="https://www.youtube.com/embed/sWH811TcckU" frameborder="0" allowfullscreen></iframe>
