12,000 lbs of cocaine seized in submarine
This is interesting. I am glad they got this stash, but what right does the US actually have 200 miles south of Mexico in international waters?
Coast Guard seizes $181 million in cocaine from sub - CNN.com
2001 911 Cabriolet |
They (state department) have to get permission from the vessel's flag nation to board if there is suspicion...if there is no flag nation, as I would expect in this case, fair game.
1992 968 Polar Silver 2010 Toyota Highlander SE 2006 Lexus LS430 ML |
In naval terms that is balast
84 Carrera Cab - ROW Thanks to this Tech forum!!!!!!!!! Tranny rebuilt etc.. Fresh Konis, Lowered front,, R&R injectors, Wonged, Valve Adjust, Electrical solutions, Next; Lower rear, Corner balance |
Thank you. That makes sense.
So the USCG are the new Pirates of the Caribbean?
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
Information Junky
So the sub ended up sinking, but most of the coke was rescued.
I expect the reason the sub took on water was because of a YouTube video. ![]() I do wonder why they wouldn't track the sub for a while.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
$11300 per pound? Is that right? Then they cut it right? Or did they work that into the numbers already?
My drug knowledge is pretty G rated Sent via Jedi mind trick.
poof! gone |
Insert Tag Line HERE.....
I saw an article in Wired magazine a few months ago that detailed these operations. They are home built subs, usually from Ecuador or Columbia. Crazy..
Now in 993 land ...
Who uses all this coke? This is amazing per capita, I am sure.
G |
My friend and I made a home made sub when we were kids. His hamster hated it. It lived, but we traumatized it for sure. ![]() Sent via Jedi mind trick.
poof! gone |
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
Team California
We do. Americans, that is.
Denis |
Cars & Coffee Killer
Did it look like this?
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
My neighbor and I built one when we were in 6th grade. We found the plans in some magazine. We soldered a bunch of tin cans together to make a long tube. The lids were all removed from the middle ones. We soldered a streamlined bow, stern and fins to that. The conning tower was a small paint can with a press in lid. It was open to the main compartment below. On the bottom of the main compartment was soldered a copper tube that was bent 90° to toward the stern and crimped almost flat at the open end. There was some ballast in the keel and a wire basket in the conning tower. There was some sort of a check valve in the lid of the conning tower, just a flap on the inside. Plop a hand full of alka-seltzer, fizzy or carbide tablets in the basket, seal the lid, put it in a pond and it would sink. Water would come in the bottom through the copper tube. Once the water covered up the tablets they started to fizz, closing the valve and forcing water out the copper nozzle. It would take off and fully surface before the fizz wore off. Only problem was it would sink for good when the tablets were used up. Then it was time to go diving to retrieve it.
They build those in the columbian jungle. Very impressive for what they are.
dolor et pavor Copyright |
1.367m later
Aww crap, there goes my weekend.
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
Recreational Mechanic
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
First sub to sink enemy ship............
That would be the Confederate submarine the Hunley. If I remember correctly, it had a crew of eight and was armed with a spar torpedo. It sank the USS Houstatonic just outside Charleston harbor. Unfortunately, the sub was also lost and not found until along about 1995 or so. It was sitting in only 35 feet of water! It is now being preserved at the old Charleston naval base.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
The one in that picture is from the show archer....
![]() And damnit! Now I need a new supplier! |
