Tire sensor questions
The GF has a Toyota Solara. The dash idiot light came on. Tire sensor. All the pressures are correct including having 60psi in the spare. The reset button gave no joy.
How do I track which sensor is faulty? I assume the sensor is inside the wheel attached to the valve stem. Once identified as to the culprit, simply breaking down the tire and replacing is the deal or is this something that requires the Stealer to program to the car? |
my TPSM light comes on when the pressure is too high as well.
you like 60psi? all the tires are 60? or just the spare? and without my OM handy, i kinda remember a faulty sensor gives a different reading than low PSI. flashy versus solid light..i think. |
35 for the road tires, 60 for the spare.
You went through the whole reset procedure?
-Inflate all tires to pressure listed on placard. -Turn ignition to on position (engine off). -If TPMS light is flashing, hold down tire pressure reset button (found on instrument panel, knee bolster, or inside glove box) until TPMS light flashes 3 times. -Once TPMS light is off, hold down the reset button until light flashes 3 times. -Drive vehicle at 19mph+ for at least 1 hour. |
If no work, repeat all. |
We have a Honda and the dealer had to reset the TPMS light after replacing the wheel sensors. I could have replaced the sensors myself but would still have to the dealer turn the frikkin' light off.
Given the van is model year 2007 I had them replace all 4 sensors. |
Lower the spare tire. I'm betting It will go
Sent via Jedi mind trick. |
Disconnect all the TP sensors. Problem solved :)
My stupid Fiat ALWAYS has one on and the dealer says he cant fix it . POS Car.
I had mine come on in the Tacoma. Turned out to be the spare.
. ~~~~~~~ . On my Rav4 it's always the spare. I don't fret too much about it...I get to it soon enough. . Who started this idea that we needed TPSM in the first place? |
Every car has a different reset procedure, sometimes they work but sometimes they don't. The tire shops have tools that they use on each wheel to reset and link the sensors, I think you can also get them online from Tire Rack and others. If the sensor is bad, many of them require you to break the bead to replace it. Google your car for specifics.
There are several hand held scanners you can get to check each sensor.
That's how I figured out which wheel.
Truthfully the car is great. But there is zero for dealer support. So for starters - To go there is a NIGHT MARE. (the dealer) They do not like the idea it was bought from another dealer from another state. They told me so. Right now the "on board what ever system says -no communication between it and sensors" " The dealer says it is too intermittent to fix. Sigh. They have fixed numerous wheel sensors, but they do not have the verve to take on this problem. This is the smallest problem I have with this car. A shifter cable breaks ever 20K miles, the first time it sat in the shop for 28 Days ! What is worse they would not give me a loaner ...and no apology from them. ALL wheel bearings have been replaced and need them renewed again.They are howling . The lower trim below the doors keeps falling off and they say they will not fix it anymore. The rear tires last 20K miles as they have 3/4 tow built in... The rear brakes seized up ..they replace the calipers . and on and on...and on and on....... Fiat did the same thing to their customers in the late 70s early 80s, they acted like they did not need them. We all are getting the point. The car is a 2013 Abarth with 60K on it. It COULD have been a great car....but the dealer has ruined the experience for me . In fact the dealers have done such a BAD job they now can be bought for about 1/3 and less then when I bought this. Kind of ruins the trade in value..LOL Run Forest run. PS, yes I have had numerous complaints into "fiat cares " trust me they do not care. |
Our immediate family has owned 17 Fiats in the past all the way back to the 60's. He thought this time with Chrysler they would make a good product and support it. He's tried trading it in and no dealerships want it. Not giving him a lowball trade in offer, they just flat out don't want it. So yeah, we agree, what a POS. |
| All times are GMT -8. The time now is 09:50 PM. |
