Rick Lee's Avatar
Where is my coolant going?
2008 Hyundai Santa Fe, 105k miles
Two mos. ago while doing my last oil change I noticed the coolant reservoir looked empty. I opened it up and it looked bone dry. I filled it up with 50/50. Just checked again, and it was down to the minimum level line. I checked the oil dipstick. No foam, oil looked as clean as honey. Car doesn't smoke, engine temp gauge never goes above about 40%, no leaks under the hood or car, no crusted antifreeze stained around engine. Where is this coolant going and what's causing it?
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 01-13-2016, 10:38 AM
wdfifteen's Avatar
Transmission cooler? Brake booster?
Old 01-13-2016, 10:52 AM
Student of the obvious
LeeH's Avatar
Have you pressure tested it?
Lee
Old 01-13-2016, 11:03 AM
Make Bruins Great Again
Por_sha911's Avatar
I had the same problem. It was a slow leak that was getting into the combustion process so it was being burned off. Compression check (to the radiator) confirmed leakage.
Joe
Old 01-13-2016, 11:13 AM
Rick Lee's Avatar
This is engine coolant. So how does it get into combustion process if a radiator leak? How did you fix it?
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 01-13-2016, 11:16 AM
It could be a head gasket issue.
Dave
1969 911T Coupe
1972 911E Targa
Old 01-13-2016, 11:17 AM
Radiator cap getting weak? Hat was the issue with my 944. Cap spring was weak letting it dribble out a little while running.
Old 01-13-2016, 11:22 AM
Kantry Member
oldE's Avatar
Rick,
He did not suggest a radiator leak. He is suggesting a head gasket or perhaps a cracked head. A pressure test, done at the radiator cap, should give you an idea of how much leakage and perhaps reveal where the coolant is escaping.
Best of luck.
Les
Best
Les
Old 01-13-2016, 11:29 AM
Rick Lee's Avatar
Yeah, I suspected a head gasket too. But shouldn't there be foam on the oil dipstick or some other evidence?
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 01-13-2016, 11:31 AM
No , not necessarily. I had a 1980 Chevy Citation 4 cylinder (Iron Puke) that did the same thing. The seepage just burns off in the combustion process and never makes it to the crankcase.
Dave
1969 911T Coupe
1972 911E Targa
Old 01-13-2016, 11:49 AM
Kantry Member
oldE's Avatar
If the leak is directly into the cylinder, it might be passed as steam through the exhaust.
Best
Les
Best
Les
Old 01-13-2016, 11:51 AM
fastfredracing's Avatar
Arent you coming up on major service like timing belt, and water pump ? Maybe some weepage from the water pump , would be imossible to see without dis assembly .
Just a thought
I am not aware of them having problematic head gaskets, at least not in this climate. I'd look real good around the crank pulley, and see if you can see any crusty-ness
No left turn un stoned
Old 01-13-2016, 12:12 PM
Rick Lee's Avatar
I had the timing belt done 20k miles and two years ago. Runs like a top.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 01-13-2016, 12:15 PM
My one time experience is occasionally I would get a misfire (Money Light) that would go away.
It was suggested I get a Harbor Freight Radiator tester and pressurize the system a couple of times. Take the plugs out and you will see a blast of coolant when you crank it.
Rick
88 Cab
Old 01-13-2016, 12:19 PM
Rick Lee's Avatar
I'm taking it in for a pressure test today. $35 and he said it'd take 30-60 min.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 01-13-2016, 12:21 PM
Have you checked the integrity of the line going from the overflow tank to the radiator?
I'd expect a leak from a head gasket to show bubbles in the radiator when cold.
Good luck with the pressure test.
Scott
'78 SC mit Sportomatic - Sold
Old 01-13-2016, 12:24 PM
GF's VW Tiguan does the same thing. We've had to add coolant a few times.
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 01-13-2016, 12:30 PM
vash's Avatar
you smelling it?
my wife's subaru was maddening. we would smell it. no visible leaks, cap was tight, etc.
pressure testing it didnt show much. turned out there was a micro crack at the thermostat housing. i used a flashlight at night and saw the wisp of steam. easy enough fix.
poof! gone
Old 01-13-2016, 12:34 PM
I'm ashamed to say we once owned a Taurus wagon that did the same thing. Turned out there was corrosion stress fractures to the head bolts on the aft bank of the V-6 and the coolant trail down the backside of the engine was out of sight until it was put on the lift. It had done this from just about the time it was new too.
Scott
Old 01-13-2016, 12:37 PM
Air Medal or two
afterburn 549's Avatar
A dye kit will tell you instantly if it is combustion related .
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 01-13-2016, 01:26 PM
