Yup, another computer question...
Last night I got my son's old laptop out and got it going. Battery showed 1% so I hooked up the charger and was running off A/C for a while. Shut it down when I went to bed but left the charger on all night figuring it'd charge up while I slept. Get up this morning and the laptop won't even turn on now.
So, rather than fight a dead battery and/or charger I took out the hard drive and now have it hooked up to my desktop via the USB port.
My problem is most of the files are protected. I can see thumbnails of some of the pictures but other files I can't even access.
What do I have to change in order to gain access?
The laptop was running Win XP if I remember correctly.
The files I can access are in a folder I created called Data. The ones I can't access are found under the usual Win file explorer tree Documents or user data.
Scott
'78 SC mit Sportomatic - Sold
Old 01-19-2016, 12:18 PM
Scott R's Avatar
Without seeing what the "locked" files look like, you most likely need to take permission of the folders on the drive.
https://technet.microsoft.com/en-us/library/cc753659.aspx
You can also do this via the command line with SubInacl, which sometimes works better and more quickly.
https://www.microsoft.com/en-us/download/details.aspx?id=23510
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-19-2016, 12:24 PM
Thanks Scott, I'll take a look at those links.
First I have to go to the in-law's and see about a garbage disposal replacement. ugh.
Scott
Old 01-19-2016, 12:32 PM
Using a Linux box can often bypass that lock
Rick
93 968 (My summer car),
05 Cayenne S (My winter car),
79 924 (Wife's summer car), 02 C230k (Wife's winter car),
Old 01-19-2016, 01:01 PM
