Yup, another computer question...
Last night I got my son's old laptop out and got it going. Battery showed 1% so I hooked up the charger and was running off A/C for a while. Shut it down when I went to bed but left the charger on all night figuring it'd charge up while I slept. Get up this morning and the laptop won't even turn on now.
So, rather than fight a dead battery and/or charger I took out the hard drive and now have it hooked up to my desktop via the USB port. My problem is most of the files are protected. I can see thumbnails of some of the pictures but other files I can't even access. What do I have to change in order to gain access? The laptop was running Win XP if I remember correctly. The files I can access are in a folder I created called Data. The ones I can't access are found under the usual Win file explorer tree Documents or user data.
Scott '78 SC mit Sportomatic - Sold |
Without seeing what the "locked" files look like, you most likely need to take permission of the folders on the drive.
https://technet.microsoft.com/en-us/library/cc753659.aspx You can also do this via the command line with SubInacl, which sometimes works better and more quickly. https://www.microsoft.com/en-us/download/details.aspx?id=23510
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Thanks Scott, I'll take a look at those links.
First I have to go to the in-law's and see about a garbage disposal replacement. ugh.
Using a Linux box can often bypass that lock
Rick 93 968 (My summer car), 05 Cayenne S (My winter car), 79 924 (Wife's summer car), 02 C230k (Wife's winter car), |
