-   -   radar detector mirror mounts- Valentine One specific (http://forums.pelicanparts.com/off-topic-discussions/900688-radar-detector-mirror-mounts-valentine-one-specific.html)
rfuerst911sc 01-31-2016 01:59 AM
I recently picked up a used Valentine One detector with the primary use to be in my Boxster. While it came with the suction cup and visor mounts I don't really care for either. Suction mounts usually let go at the worst times and leave outline rings on the windshield. Visor mount may work but what happens when you need the visor :confused: Poor design in my opinion. So now looking for a mirror mount but the Boxster/996 cars the mirror shaft is quite short and mine has a flat spot on the shaft at the top. So does anyone make a mirror mount that actually fits ? Or are you guys modifying the mounts ? Any pics with links would be helpful. Or if anyone has one for sale even better :D
TimT 01-31-2016 06:10 AM
I picked up one of these a few years ago
Valentine Radar Mounts
masraum 01-31-2016 06:11 AM
This is what I have.
Porsche radar detector mount
rfuerst911sc 01-31-2016 06:21 AM
I like everything about the Blendmount except the price :D Having said that how well does it fit ? If the pictures are accurate on the website it looks like it tucks the V1 detector up tight under the mirror. Do you find that the detector blocks any view angles or is it high enough to not be in the way ?
rfuerst911sc 01-31-2016 06:25 AM
Tim are you using the 23mm size mount ? Any issues with windshield clearance ? This has to mount on the portion of the mirror stalk that is right by the glass. The straight portion of the mount to my eye looks like you would have to have the bottom adjustable part all the way to the bottom other wise it would hit the glass. Hard to explain. Do you have a side pic of yours installed ?
masraum 01-31-2016 06:38 AM
Yeah, it wasn't cheap, but I think it was the only option for my mirror. I think the Boxster's varied quite a bit over the years, especially when you start adding the auto-dimming mirrors.
It tucks up very close on mine. You can't get your finger in between the bottom of the mirror and the top of the detector, but there is plenty of room to adjust the mirror.
I thought that it might block my visibility some, but because it sits so high, it's not a problem. Because I have the auto-dimming mirrors, I was also able to get a short cable and tap into the power inside the mount which was nice.
rfuerst911sc 01-31-2016 06:43 AM
A few follow up questions if you don't mind. Does your detector seem to work good in this location ? In your opinion is the rear antenna in the V1 lined up with the rear window or is it picking up radar through the cloth of the soft top ? My O2 S has a manual dimming mirror as long as there is enough clearance to manually move the dimming lever I would be happy. Any pics of your setup ? Thanks for the feedback.
Porsche-O-Phile 01-31-2016 06:44 AM
I really like the idea of these - they're way expensive but I similarly am sick and tired of the stock V1 mount coming unstuck at inopportune times. Thanks for the link - probably going to order one.
masraum 01-31-2016 07:07 AM
Works well. Like in my miata, I think that having the detector up high in a low car is the best spot. If you think about the fact that the rear-view mirror's purpose is to give a clear view out of the rear window, I think you'll understand how the detector being under the mirror gives it a nice clear shot through the window.
There is some space under the mirror, but since my mirror and mount are a little different than yours, I couldn't say how yours will be. I would assume there will be enough space. Also, the mount is adjustable. I have mine adjusted to get the detector as close to the bottom of the mirror as possible.
I think I have had some pics at some point but can't find them. I'll try to remember to take some more today.
masraum 01-31-2016 08:54 AM
This guy has a manual dim mirror and it looks like he has plenty of room.
https://www.blendmountforum.com/forum/porsche/boxster/628-porsche-boxster
5String43 01-31-2016 09:52 AM
Yes, the suction cups do leave round marks on the glass. They wipe off. I moisten the surface of the suction cups on mine with a slight smear of saliva and they never, ever come loose unless I want them to. Also, I prefer to mount my V1 down low, right above the dash. Seems to me it's less visible to other drivers and the cord is not dangling from the sky.
What matters, though, is that the V1 is a very effective device, however one mounts it.
Por_sha911 01-31-2016 10:20 AM
Have had a V1 with suction cup mount for about 12 years. Yes it does come off about once every 2 years (usually due to high heat of summer). I do it in this order:
Remove the detector from the mount
Clean the inside glass extremely well
Moisten the suction cups before pressing onto the glass.
I'm good to go for a few more years.
masraum 01-31-2016 11:33 AM
I figure that mounted up high (usually beside the rear view mirror) in a short car means that other folks, other than those in other low cars, won't be able to see it. I've always used a straight cable, like a black telephone cord (not coiled) and routed it around the windshield trim to the rear view mirror. I also wouldn't want the cable hanging down. If I use the thing for whatever reason with the coiled cable that plugs into the cig lighter, then yes, I usually put it low to avoid the cable.
rfuerst911sc 01-31-2016 12:12 PM
Great pics that really helps thanks.
GH85Carrera 02-01-2016 06:31 AM
I have the blendmount in my 85 Carrera. I switched the mirror to the automatic dimming mirror with the buttons for the garage door and temperature probe. I liked that mirror so much I put one in my 86 El Camino.
The blend mount is great. It tucks it up out of the way and I seem to have great front and rear coverage.
Henry hill 02-01-2016 03:53 PM
I have a V1 with a Blendmount with a wire tap coming out of the power for the rear view mirror. Have had this set up for the past four years and LOVE it. When I'm in the 911 I have the cord it came with and a visor mount.
Henry hill 02-01-2016 04:01 PM
181682301158
eBay mirror Tap
rusnak 02-01-2016 04:12 PM
I didn't want the V-1 hanging off the rear view mirror, so I glued a telephone wire modular plug onto the windshield rubber. I made a custom coiled cord from some extra phone coiled cord with plugs that I bought at radio shack. It ended up really slick. Now the V1 sits right under the mirror out of my line of sight, and no ugly cord dangling to the ciggy lighter.
flatbutt 02-01-2016 08:17 PM
Mounted on the mirror makes it impossible for me to snatch it down on those rare occasions when I do get pulled over. Here in jersey those things piss the LEOs off big time.
froggert 02-02-2016 06:53 AM
I have mine stuck to the windshield above the mirror. A piece of clear packing tape on the windshield dots and fresh suction cups every few years ensures that the V1 stays put.
