Puny Bird
Funny thing is the mph and kph conversion is real simple
50km/h is 30mph, 60km/h is 40mph, 80km/h is 50mph, 100km/h is 60mph 120km/h is 75mph Those are not exact, for example I know that 100kph is really 62.1 mph, but it's close enough. At 100km/h or 60mph I will cover roughly the same distance in one hour. When I first began to drive I would do the conversion from mph to km/h, now it's km/h to mph. Also In case you're on the ball and noticed I used km/h and kph, both are acceptable. BTW it took way longer to type this, than to do the conversion, again I did the conversion in my head in seconds.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
UK continued to use SAE and Imperial standards e..g measurements, gauge, threads - in engineering for somewhat longer than that. But pretty much the only pre-decimalization measurement that remains now is the pint of beer/cider/milk. Sacrosanct. Oh, and troy ounces for precious metals. NZ switched to the NZ dollar in 1967, Australia decimalized in 1966.
'77 S with '78 930 power and a few other things. |
After every fill I write the kilometres travelled on that tank on the gas slip and calculate the kilometres per litre. I confess that I then convert to miles per Imperial gallon, by multiplying by 2.84. ![]() |
Same reason the Chicago to New York train- takes hours longer than it did 100 years ago. Kind of.
Modern version: The Acella Train ( D.C. to Boston) was suppose to take x mount of hours but they translated the width off the tracks (inches) too wide compared to the spacing of the wheels ( Metric ) European train on American tracks. Train cannot reach top-speed.There is also the fact that the tracks are too "bumpy" which has less to do with measurement..
jt '83 SC '96 M3 6 Bicycles 2 Sailboats Last edited by Kraftwerk; 02-06-2016 at 07:39 AM.. |
Checked out
Just saw this on a knife discussion
![]() Sent via Jedi mind trick.
poof! gone |
Puny Bird
The Apollo Guidance Computer was programmed in SI, but displayed and accepted data in English units. ![]()
I just multiply KPH by .6 to get MPH. The math is easier for me than memorizing a conversion table, and it's fairly close.
Puny Bird
Anything out of the normal car speed range and I'd likely have to do the math. I no longer convert most measurements, it's the same as learning a 2nd language, if you use it every day you will be fluent, if you stop using one you will forget quickly.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. Last edited by Mark Henry; 02-07-2016 at 06:08 AM.. |
Information Junky
"Why aren't we using the metric system?? "
We are. The US uses both. I use SI daily. (engineering) And don't drug dealers, for the past 5 decades, sell by the gram? or is it oz?
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee. ![]() |
Thread Tools | |
Rate This Thread | |
