thermodynamics and basic mechanics suck in US units. When I was in school I did all my non symbolic work in metric and then converted back to metric in the end. It was too easy to miss points by being off by 32.2.
The golden engineering rule of "always carry your units through" breaks down in some instances for SI.
Many places use mixed unit systems as customary.
The reason why we don't switch is a good lesson in what drives adoption in my opinion: need and not just convenience. It would be a giant PITA for alot of industries and the upside is only slightly less annoyed technical staff. People dont care that much about annoying others slightly less.
07 Exige S
Old 02-01-2016, 08:44 AM
vash's Avatar
i'm still not 100% sure what a "Slug" is.
in college, our problems came at us in both flavors. the metric problems were a lot easier for sure. but i managed both. a miracle of sorts..
it would be very expensive to swap the USA over. california tried it (for projects), and backed out after a year of transition.
poof! gone
Old 02-01-2016, 09:08 AM
Control Group
Tobra's Avatar
Originally Posted by john walker's workshop View Post
90% of the population has pablum for brains is why.
This
In medicine, there is a lot of metric. Doses are mg/kg, for example.
As stated above, tires are in inches all over the world, go figure
Old 02-01-2016, 09:43 AM
wayner's Avatar
This
Really? Mine are 245mm in the front and 275mm in the back (on 17" rims mind you)
SOLD - 914 wide body hot rod
Old 02-01-2016, 10:45 AM
Yep, that 17 inch diameter or whatever the diameter is, will be inches.
I always thought it was funny that the tire width is almost always in mm but the rim size is inches.
I have always wondered just how wheels are sold in China or Iran to local customers. Are those still sold in inches?
Old 02-01-2016, 10:56 AM
hardflex's Avatar
wasnt' there a space mission that failed a few years ago because someone didn't carry the units out correctly in the formula? Didn't convert from Metric to English or vice versa?
I think the English lengths, inches, feet, yards, miles, makes as much sense as scoring in Tennis.
72 914 2056: 74 9146 2.2: 76 914 2.0
Old 02-01-2016, 11:25 AM
wayner's Avatar
They actually make a lot of sense
-The distance between your first and second knuckle on your index finger is an inch
-A foot is a foot
-An outstretched arm is a yard
-Two outstretched arms from tip to tip is 6 feet
-A span between outstretched pinky finger and thumb is 6 inches, or half a foot.
It goes on...
Old 02-01-2016, 12:11 PM
creaturecat's Avatar
Hegemony. American.
It is sort of like biting your nose to spite your face.
Is there a truly valid reason?
Old 02-01-2016, 12:20 PM
wdfifteen's Avatar
I think that's called a dick, and it's 10"
Right?
Old 02-01-2016, 01:27 PM
wdfifteen's Avatar
This
Tires come in 400mm size. I'm not sure if there are any other metric sizes though.
Old 02-01-2016, 01:30 PM
UnRegistered User
billybek's Avatar
I know there was this when Canada switched to SI.
https://en.wikipedia.org/wiki/Gimli_Glider
Bill K.
Old 02-01-2016, 01:51 PM
White and Nerdy
Tervuren's Avatar
When I started cooking as a hobby a few years I realized recipes make the US system look easy.
Ounces can be either a volume or a weight, you determine which to use based on the contex
People who write recipes pay no attention to repeatability of results. I've converted my favorite recipes to volume for liquids and weight for solids so I can repeat them if I want. I'm thinking of going to weights.
3 large tomatoes
1 medium onion
4 oz ground beef
2 oz beef broth
is basically meaningless if you want to repeat it accurately
OTOH, when I was a kid my mom took me to the doctor who gave her some powdered medicine for me. The prescription was to give me "about as much as you can pile on a dime."
To be correct, they should use Fluid Ounces for volume.
Shadilay.
Old 02-01-2016, 02:30 PM
Puny Bird
Mark Henry's Avatar
One would think the little winkie crowd would be all for it ....afterall 4 inches is 10.5.....cm
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 02-01-2016, 03:15 PM
Just thinking out loud, what if we appoint the day as the basic metric unit of time and then do centi hours, milli hours etc?
Things would get a bit out of hand when seasons change every .356 kilodays
It sounds a bit odd, but maybe because we are only so used to "non metric" time.
07 Exige S
Old 02-01-2016, 03:26 PM
MBAtarga's Avatar
NASA- Mars Orbiter failed:
Nov. 10, 1999: Metric Math Mistake Muffed Mars Meteorology Mission | WIRED
Mark
'83 SC Targa - since 5/5/2001
Old 02-01-2016, 04:05 PM
DanielDudley's Avatar
Years ago, my dad sent me to order some window sash for a pre revolutionary war colonial. I said to the fellow, I need to order some custom windows. He asked me how I knew I needed custom windows instead of a standard size. Well, I said, it's a pretty old house. Well, he said, it's a pretty old standard.
He was right, they were a stock size...
Old 02-01-2016, 06:19 PM
Make Bruins Great Again
Por_sha911's Avatar
Did ya ever notice that you snap that 10 mm socket onto a 3/8 ratchet?
Joe
Old 02-01-2016, 07:21 PM
UnRegistered User
billybek's Avatar
Actually that is 9 1/4 mm....
Bill K.
Old 02-02-2016, 04:33 AM
wayner's Avatar
Originally Posted by NotaBRG View Post
Mine is 9 3/4" FWIW.
Thats why women are such poor judge of distance. For years the've been told this is 6"...
EDIT:
I got that one wrong. Its supposed to be if you form an L with your thumb and index finger.
Old 02-02-2016, 11:06 AM
Counterclockwise?
For the same reasoning you think a slotted screw is better than a Robertson.
Rod
1986 Carrera
2001 996TT
Old 02-02-2016, 01:50 PM
