id10t's Avatar
Originally Posted by Scott R View Post
At 1000MB on CAT 5e you can get a reliable 30 meters given the consumer class switch and router (that I assume you have). To test this theory you can hard code your ports to a slower speed, if possible, something like 10MB/Half and see if it negotiates.
However this all for not with a bad cable, and it really sounds like you have a bad or poor cable, or possibly a bad switch port or patch somewhere in there.
I've done full length (100m per spec) runs using home grade equipment and it worked well enough to feed 6 hi-def video streams for several hours and no glitches. Cable run from a gibbon enclosure to front of zoo for an event that normally happens in/through the zoo but the little slut monkeys made a baby unexpectedly and gave birth 3 days before the event, so they didn't want the crowds coming through. Had cables gaffer taped to trees, all sorts of crazyness to make it work. But it worked.
Old 02-12-2016, 02:44 PM
peppy's Avatar
I guess the good news is I did order a cable tester.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 02-12-2016, 02:58 PM
peppy's Avatar
I was playing with my new cable tester yesterday and connected it to the garage run. The lights were all over the place. I must have been color blind when I connected the jack in the garage (and when I double checked), because it wasn't even close. I guess you can wire up the jacks wrong and they will still work.
I also found patch cables that i made that were working, but wires were crossed.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 02-26-2016, 10:10 AM
Registered Offender
stinkindiesel's Avatar
Most newer GbE physical layer devices (the piece of silicon that drives the copper cable at both ends of the wire) are capable of automatically detecting cable pair P/N reversals and pair/pair swaps just because cable pullers can't build cables correctly
It's also been at least 10 years since I've seen even a consumer grade switch that wasn't capable of establishing a valid link across at least 150 meters of decent CAT 5 or 5e cable. Length should not be an issue for you.
Gary
Old 02-26-2016, 10:53 AM
