vash's Avatar
old butcher table. belt sander?
i have an old OLD table. from my family's grocery store. kept it because i remember it from my early childhood.
thinking of putting it to use, but i need to fix the top. it has just been bouncing from my garage to garage..getting nasty.
i have not rebuilt brake calipers on it, but...you know.
belt sander? i email a company that does big gigantic planing work. i borrowed a belt sander, but staring at 1800 square inches, with that tiny sander is a bit intimidating. 30x60"
i want it perfectly flat to use as it was intended. no meat, but it will be a bread table and such.
i have a good friend that makes cutting boards and he said he would use a belt sander. i imagine a belt sander in his hands and a belt sander in my hands are completely different scenarios.
poof! gone
Old 02-08-2016, 04:54 PM
Is the surface deeply gouged or just dirty/stained with some nicks and cuts? Being such a large surface, if you can remove the legs an lay the top on the floor, you may consider renting a floor sander used to refinish hardwood floors.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 02-08-2016, 05:03 PM
Find a woodshop or mill shop that has a wide belt or drum sander. They usually take jobs like yours and run it their their machine to get it dead flat. Normally charge down here is about 80 bucks. Mske sure there are no nails and such or oil because they can damage their sanding belt. Look for belt sanding service. Forget the belt sander or using jigs and router. Its just not worth the time IMO.
Old 02-08-2016, 05:06 PM
Vash,
Check around at a few cabinet shops. The one down the road from me has a wide belt sander and charges $30 for a half hour of work. Your top would be perfectly flat and beautiful.
Rutager
Rutager West
Old 02-08-2016, 05:07 PM
Great minds think alike, lazy ones too!
Rutager West
Old 02-08-2016, 05:08 PM
Call MacBeath Hardwood. The one down here did little bit of stuff like that. I know there's one in SF.
Not worth messing around with hand held power tools. Need to bring it to the pros and run it through their machinery.
Old 02-08-2016, 05:10 PM
LAZY??? Thank you very much.
Old 02-08-2016, 05:11 PM
Home Depot rents out floor sanders. I was looking at them when I rented the bucket lift.
Old 02-08-2016, 05:16 PM
Monkey+Football
Icemaster's Avatar
Send a message via AIM to Icemaster
This.
It's not lazy, it's the right tool & expertise for the job you're looking for.
<Insert witty comment>
85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff.
Old 02-08-2016, 05:17 PM
Originally Posted by Icemaster View Post
This.
Its stupid cheap too
Old 02-08-2016, 05:19 PM
In this particular case, lazy is probably cheaper and the results much better, got to love lazy!
Rutager West
seriously man, I agree 100%
Old 02-08-2016, 05:20 PM
MRM MRM is offline
Smarter is not lazy. It's smarter. Do it the easier (smarter) way to get the job done.
MRM 1994 Carrera
Old 02-08-2016, 05:29 PM
vash's Avatar
Thanks guys. Emailed a local mill. I had no idea there was a mill here. I'll follow up with a phone call.
It's pretty beaten down but should be nail free. No oils.
Sent via Jedi mind trick.
poof! gone
Old 02-08-2016, 05:42 PM
The Unsettler
stomachmonkey's Avatar
One of my best traits is laziness.
Makes me highly efficient.
"I want my two dollars"
"Brandon Won"
Old 02-08-2016, 05:43 PM
devodave's Avatar
Exert yourself!
Enough of this laziness! Find someone with a hand jointer plane and flatten it by hand. It will be a great workout, quiet, and reasonably dust free. Couple of winding sticks to make sure you are proceeding correctly, and you're home free!
David Gray
71 Gemini Blue Metallic 911T
Old 02-08-2016, 06:07 PM
Functionista
manbridge 74's Avatar
You had me at OLD. Get thee to the mill on time...
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 02-08-2016, 06:18 PM
Model Citizen
herr_oberst's Avatar
Looks like a Boos table?
After they take down the top, consider having them knock down the edge with a 1/2 inch roundover bit.
Old 02-08-2016, 06:27 PM
Reg Reg is online now
Reg's Avatar
^^^this
In our shop we do not usually sand used old tops because they're typically dirty, not flat and too time consuming to make look good. Seeing what can be done by skilled hands with the right hand tools is impressive!!
1970 911 t (sold)
1985 MR2 (sold)
2011 GT 5.0
2007 CRV
Old 02-08-2016, 07:09 PM
Danimal16's Avatar
When I was doing cabinets I would go to the mill after they had completed a big job. The mill would run my glue ups on the used sander belts and charge me about 50 bucks for a half hour run.
Dan
Old 02-08-2016, 07:28 PM
