-   -   Big Engine Damage (http://forums.pelicanparts.com/off-topic-discussions/904471-big-engine-damage.html)
daepp 03-01-2016 01:08 PM
Big Engine Damage
For the PPOT Brain Trust:
2008 Navastar (International) DT466 - 6 cylinder in line diesel. Was running just a little bit rough... Loss of power, no lights whatsoever on the dash (and there are MANY) were lit up.
So my question is, what do you think happened? My mechanic says the bent pushrod is from #4, and the bad lobe is #2. I can't make sense of that.
http://forums.pelicanparts.com/uploa...1456866229.jpg
http://forums.pelicanparts.com/uploa...1456866255.jpg
#2 Cam lobe
http://forums.pelicanparts.com/uploa...1456866285.jpg
http://forums.pelicanparts.com/uploa...1456866318.jpg
Another lobe starting to go:
http://forums.pelicanparts.com/uploa...1456866353.jpg
http://forums.pelicanparts.com/uploa...1456866397.jpg
What I think is a good lobe:
http://forums.pelicanparts.com/uploa...1456866429.jpg
sand_man 03-01-2016 01:13 PM
Whoa! Lots of "bluing" (heat) on that camshaft.
FLYGEEZER 03-01-2016 01:17 PM
It looks like your engine s*** itself.
nota 03-01-2016 02:10 PM
cam metal looks like it was full of airbubbles
when I got a core motor to rebuild for a 455ho gto
the cam had wiped out two lobes
but they were wore down WITHOUT PITS OR HOLES
i WOULD E-MAIL THOSE PIC'S TO THE CORPS REP
a bad casting with tooo much air intrained prior to machining is my guess
daepp 03-01-2016 02:13 PM
Thanks. The engine had 150K on it, and I was told the driver must have miss-shifted. After I saw the parts I started to wonder.
pcardude 03-01-2016 02:14 PM
Dang. That cam is a disaster yo. How many miles are on it?
daepp 03-01-2016 02:17 PM
150,000 miles on the odometer, but the truck was purchased used. Actual mileage may be less.
sammyg2 03-01-2016 02:19 PM
http://forums.pelicanparts.com/uploa...1456870729.jpg
http://forums.pelicanparts.com/uploa...1456870741.jpg
Dan J 03-01-2016 02:24 PM
Typical Binder. Fix it sell it buy a truck with a Cummins
daepp 03-01-2016 02:39 PM
Binder?
ckelly78z 03-01-2016 02:48 PM
In the rubber industry, we call all those tiny bubbles....porosity. Never seen it in a cam lobe, but obviously, the cam maker had a heat issue while molding the cam. Possibly not a long enough cure time, or excess gassing.
aigel 03-01-2016 02:50 PM
I buy the over-rev. theory. Lobe wear is one thing, but lobe chunks and bent pushrod? Manual trans?
G
pete3799 03-01-2016 02:58 PM
Originally Posted by daepp (Post 9019315)
Binder?
Corn binder some times referred to as a 13 letter s&!t spreader.
Like Dan said rebuild it and get rid of it.
wdfifteen 03-01-2016 02:59 PM
http://forums.pelicanparts.com/uploa...1456873152.jpg
This grove worn into the cam is not from over reving. I'll go with bad cam. Improperly hardened.
daepp 03-01-2016 03:02 PM
Engine has been rebuilt. I am not up on California smog rules as I should be, but a Cummins swap would strike me as not at all possible.
rfuerst911sc 03-01-2016 03:17 PM
One can of Engine Restore or Slick 50 you'll be good to go :D
pete3799 03-01-2016 03:22 PM
Don't swap motors swap trucks. We just traded a 2011 International with a Maxxforce motor(most unreliable motor I've ever seen ) for a new Kenworth with a 485hp Paccar motor.
1990C4S 03-01-2016 03:25 PM
Rebuilt with a ****ty cam I think. Was the oil pressure good?
sand_man 03-01-2016 03:48 PM
I know nothing about this engine, but I wondered the same...oil starvation?
Rusty Heap 03-01-2016 04:02 PM
Dr McCoy pointing to never seen before member of the Star Trek security landing party wearing the red uniform shirt:
"He's dead Jim"
