Two Cylinder Engine Question
I was 'given' a two cylinder engine for a small home project, but it has no starter.
First issue is to figure out which way it should rotate.
I would think the easiest way is to look at the valves while I crank it manually, and make sure it sucks through the intake (and intake valves) and exhausts out the muffler (and the exhaust valves)?
Yes?
Old 04-04-2016, 12:16 PM
Arizona_928's Avatar
50:50 shot. Just try to run it? My money is on clockwise...
dolor et pavor
Copyright
Old 04-04-2016, 01:14 PM
Clockwise rotation when facing the engine (i.e. output shaft at rear) is normal I think...
So standing at the front of your RWD car engine's typically rotate CW. I think.
Old 04-04-2016, 01:27 PM
you're right ^^
The only ccw rotation I can think of would be marine for dual engines....
dolor et pavor
Copyright
Old 04-04-2016, 01:28 PM
Fast Acting, Long Lasting
Originally Posted by AZ_porschekid View Post
you're right ^^
Corvairs, some older Honda, and Mitsubishi 4 cylinders also turn CCW.
Eighteen ways to burn fuel.
Old 04-04-2016, 03:05 PM
wdfifteen's Avatar
I would start by identifying the make and model. With that info you can probably find a manual on line that would provide all kinds of useful information.
Old 04-04-2016, 05:00 PM
dang it... you caught me... I was thinking Corvairs after I wrote that. I don't think I have personally ran into any besides marine, and Crovairs.
dolor et pavor
Copyright
Old 04-04-2016, 06:39 PM
one of gods prototypes
bell's Avatar
Turn it by hand and check for suction on the intake
Brought to you by Carl's Jr.
Old 04-05-2016, 03:57 AM
Thanks guys. I think I have this now...
Old 04-05-2016, 04:00 AM
