Fleabit peanut monkey
Bob Kontak's Avatar
2003 Navigator - Plug wear consistent pattern
2003 Navigator 5.4 Engine. 125k Title should be inconsistent wear.
Changing plugs and coil over plugs. General PITA but doable with a few tears.
Factory gap - 52-56 thousandths. As I move to the back of the engine pulling plugs, they are 70 thousandths in front and move up to 95 thousandths in the rear on pass side. Driver's rear is 87 thousandths. Almost linear in progression.
Heat related?
I have seen gaps of 125 on clapped out Windstars. They can run with fat gaps, but why the non-uniform wear?
1981 911SC Targa
Old 04-25-2016, 06:01 PM
Functionista
manbridge 74's Avatar
How was getting plugs out? Need to do my 05 5.4L.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 04-25-2016, 07:50 PM
Pcv is connected to back of the intake. Those cylinders see the most oil vapors, tapering off as you work your way forward. Also with water pump in the front, those cylinders further away run hotter.
Old 04-25-2016, 08:32 PM
Bob Kontak's Avatar
Never thought about PCV. Cool.
1981 911SC Targa
Old 04-26-2016, 07:47 AM
Bob Kontak's Avatar
Two different animals. The 03 does not have spark plugs that break.
For your 2005
Use an agent in your gas across many weeks that loosens up carbon from the inside .
Remove plugs with engine hot.
Have a Lisle extractor tool on the workbench.
1981 911SC Targa
Old 04-26-2016, 07:58 AM
