That beastie would be a hell of a track car with a couple more gears. The Porsche crowd would be in for a shock......that is an excellent case for "Modern". He's pulling 380HP at the wheels for now (@ 2.0L) at (WAG) 1/4 the price of Porsche power. |
Probably a good thing you took out 1st and reverse from your gearbox... JR |
I tried to do it "once" with a 901 box.....I got off gently. Your statement shows a lack of experience...... maybe OK in theory. I now have a Miata. That 6 speed is almost as slick shifting as a T-10. I've never driven a Porsche with the BW syncro set up.......and ,as a result, with hold opinions of them. |
I just choose to treat my gearboxes, and everything else, like they should be treated. I don't drive (or ride, in the case of bikes) like a Neanderthal... I'm out of here, I think. Sugardude has his questions answered and I can't stand to listen to red-breard's acid trip again... JR |
http://forums.pelicanparts.com/porsche-911-technical-forum/762965-worlds-lightest-930-transmission.html |
Holy crap! The old transmission part prices are out of control. I remember complaining when sync band went from $20 to $40. Wow. Rebuilding a 901 will be mighty expensive these days.
Sorry, but could you elaborate on how/why it narrows the gap? I would think the engagement teeth wearing down would increase the gap, unless you are saying the dog teeth make less contact? |
<iframe width="560" height="315" src="https://www.youtube.com/embed/wCu9W9xNwtI" frameborder="0" allowfullscreen></iframe>
A top notch product which, unobtrusively, dose it's job. Matt is now the HMIC there. |
If you were to test how smoothly new engagement teeth plug into a new shift sleeve and compare this against the worn out parts, the difference is quite evident. |
http://forums.pelicanparts.com/uploa...1463704739.jpg
I refreshed my 915 over the winter, and was so damned proud of myself that I couldn't bear to just put it in the garage until it went in the car. Hoping to get the car buttoned back together this weekend, and I am REALLY anxious to see how it shifts. I've had the more typical Borg Warner style transmissions/synchros apart before and it is pretty intuitive when the parts are in your hand. However, even after having the synchros apart in my 915 transmission, I still don't really get it. |
http://images.thesamba.com/vw/gallery/pix/1116841.jpg |
Here is a worn slider - Photo is nearly 15 years old!
The slider wear in two ways: 1) The sync band contact spreads metal, making the double pointed areas wider, making it harder for the dog-teeth to engage. And the pointed areas wear against the dog-teeth, rounding, usually because the sync band is worn and not making good contact. http://forums.pelicanparts.com/uploa...1463708034.jpg Sorry this first gear slider is a little out of focus, but you can see the rounded points. http://forums.pelicanparts.com/uploa...1463708390.jpg The dog-teeth are softer than the slider, so they wear out faster... |
A good shot of a rounded, worn slider
http://forums.pelicanparts.com/uploa...1463708517.jpg Here is my attempt to clean up a 1st gear slider in a 901. I used a file in between the grooves to bring them back to spec. Then I used a dremel to repoint the triangular area. At the time, 1st gear sliders were not just expensive, they were hard to find. A repointed slider with a good sync band and new dog-teeth restored function. http://forums.pelicanparts.com/uploa...1463708940.jpg http://forums.pelicanparts.com/uploa...1463708964.jpg |
Differences between dogbox, dog teeth, syncho, 915, G50, modern gearboxes
Thank you both very much for the pictures and enhanced explanation. |
901 gear stacks before being put back in a transmission
http://forums.pelicanparts.com/uploa...1463709386.jpg Some fun pictures - really broken stop blocks and brake bands http://forums.pelicanparts.com/uploa...1463709620.jpg |
| All times are GMT -8. The time now is 08:36 PM. |
