Differences between dogbox, dog teeth, syncho, 915, G50, modern gearboxes
Does the 915 fundamentally differ from modern gearboxes? Or does it have more in common with a modern gearbox than you'd think? More specifically, synchros.
Is the 915 meant to be operated in a fundamentally different way than a G50 or a Sentra gearbox? When I shift my 915 gearbox, I don't force it. Sometimes, if I feel a resistance, I lightly maintain pressure on it, and then it slides into gear. I understand this to be normal. Would this also be the case in a G50 or Sentra? Or are they totally different? Is this attributed to the synchro? Does the synchro (or something else) need to speed up to match or something? Does this not apply to modern gearboxes? Is the 915 part of the "Syncromesh" paradigm? What about "dogbox" ? Is dogbox even more primitive than the 915 ? Or is the 915 a dogbox style gearbox? Where does the G50 and a 2005 Sentra gearbox fit into all this?
1986 Bosch Icon Wipers coupe. |
kevin we are waiting for your informed treatise.. thanks in advance! matt.. how about you!
Kantry Member
I suspect the syncros on your 915 are a bit worn, but are still doing their job. Dogboxes are not necessarily more primitive, there are no syncros. Here's a pretty good explanation from superstreet dot com. "Dog engagement is normally used in racing applications where fast, precise shifting is needed. Dog gear engagement is facilitated by numerous large teeth (dogs) that mate into matching openings machined into the opposite surface of the drive gear. Unlike the synchro engagement, there is no synchronizing mechanism to assist in equalizing speed. Ideal gear selection—e.g. minimal clashing and wear of the dog rings—is achieved by quick shifts; the motto here is “the quicker the better”, so bang away." Best Les
Best Les My train of thought has been replaced by a bumper car. |
gearhead
If my replica thread hadn't been moved here I wouldnt even be checking in to this shyte hole.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Tru6 Restoration & Design |
canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Here
Let me google that for you Synchromesh vs. Dog Box - Gearbox Beatdown - Import Tuner Magazine Synchromesh Transmissions vs Dog engagement Synchro vs. Dog Box : Racing by LotusElan.net Dog engaged transmissions aka the “Dog Box” | Automotive Thinker - Discussing the finer points of automobiles Dog engaged transmissions aka the “Dog Box” | Automotive Thinker - Discussing the finer points of automobiles Ask the Best and Brightest: Dog Engagement vs. Synchromesh - The Truth About Cars Quote:
It's my understanding that Porsche invented a syncro system for transmissions, and therefore pretty much all of their stuff has been synchronized. I guess it's possible that some of the early stuff wasn't.
I had a guy try to sell me an SC once who tried to tell me that 1st wasn't synchronized. He was either a scheister or horribly misinformed. Porsche Split-Ring Synchromesh Quote:
Have a nice day!
As I understand it, Porsche finally gave up on its own method of shifting gears and went to the BorgWarner syncro set up.......I think that was when they came out with the G-50 trans.......a much better arrangement.
JPIII Early Boxster |
That's my understanding as well.
gearhead
Then you should have used GREEN FONT
gearhead
Sorry. Call me noob. I live in a world where nothing in an OT forum is taken seriously.
gearhead
Shaun,
What's that silly looking silver thing in the middle of this picture? Does that go inside of a transmission?
gearhead
![]() ![]() Is this a dog box?
Mighty Meatlocker Turbo
I don't know when they changed, but the compressed ring system used on my 519s are very slow. From 1 to 2 you need to shift fast and hard and not worry about the noise. The 741s were a little better. I understand the 901 was a 741 with more gears.
gearhead
The 924, 928 and 944 we're the first to get Borg Warner style Getrag gearboxes. The 911 kept using the 915 for another ten years because the whole car was on the chopping block and they weren't going to invest in a new gearbox for it. Only once it got a stay of execution did they commission the G50 Getrag gearbox and out Borg Warner syptyle syncrhos in the "flagship" as well.
