ACAJUN
Home Water Heater Fixed
Hi,
I searched for an answer to the problems I was having with my water heater (OK, hot water heater as it's more commonly known). Google led me to this post:
Originally Posted by randydevinney View Post
Air can not get sucked into a pressurized system. If an electric water heater is spurting air and there is none in your cold water, the cause is ALWAYS a burned out element. The insulation breaks down and the element makes contact with the water. Current then flows from the element through the water. This heats water just like in a steam humidifier but generates a lot of gas. If you have the skill to safely test the element with a multimeter you will see. It is almost always the lower element.
Thanks to this forum and more specifically randydevinney
AC
Old 07-19-2016, 02:04 PM
