I think its the cheapest solution. Another very important thing is to get rid of the stagnate hot air neat the highest paint of the roof. it helps a lot.
This may help, a little.http://forums.pelicanparts.com/uploa...1532418564.JPG
I found a 2" product at HD (Rmax Thermasheath-3 2 in. x 4 ft. x 8 ft. R-13.1 Polyisocyanurate Rigid Foam Insulation Board) and calculate I will need 8 sheets to complete the inside coverage (again wedged in between the support beams). This product has a foil coating for reflective property. Question 1, does the foam need to make contact with the inside ceiling or would it be better to leave a 1" space for more heat isolation? Question 2, I have read that this product needs to be protected from fire as it causes dangerous gas when exposed to flame. So is my idea of covering with ship lap a no go and I should be looking to enclose the insulation with sheetrock instead? If so would 1/2" be sufficient or do I need to go with 5/8"? That would be a bummer. Or should I use a different rigid foam product? Thanks! |
Fire rating of wood is better than you would think. How do you demonstrate the fire resistance of exposed wood members using char methods in lieu of gypsum? - WoodWorks
As I recall a 2x4 has a 60 minute rating, as used for firestops. Typically there is an air-gap above bat insulation in cathedral ceilings, not insulation sprayed foam. That is to prevent condensation issues. I would do a bay as a test, then check it in a few months before you do it all. |
| All times are GMT -8. The time now is 11:24 AM. |
